11-06-2008, 02:52 PM | #1 |
Quarry Creeper Join Date: Jul 2008 Location: Lawton
| Axle grease?
Ive got my axles tore down and Im gettin ready to put them back together and I want to add some more grease. Can I get some at like walmart? and If so what kind?
11-06-2008, 02:58 PM | #2 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
11-06-2008, 03:03 PM | #3 |
Quarry Creeper Join Date: May 2008 Location: ncrccrawlers.com
I bought the big tube of white lithium grease from walmart for $2 and filled the entire diff. I have been running like that for 2 months will no ill effects. I also gained 4oz of weight down low per axle from the grease. Some will say it is a waste but considering it will take $10 in stick on wheel weights to do the same thing I thought it was reasonable.
11-06-2008, 03:11 PM | #4 |
Quarry Creeper Join Date: Jan 2008 Location: In the corn
I use two different types of grease for different rigs light and fast gets Tamiya ceramic grease heavy and slow gets shooters choice all weather firearm grease |
11-06-2008, 03:13 PM | #5 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
i use phil wood grease for bike bearings. works awesome.
11-06-2008, 03:23 PM | #6 |
I used white Lithium grease until I discovered Rocksmith's "GearJelly" he's got some secret stuff in his compound that holds and actually penetrates into the gear surfaces like skunk smell on a dog. I originally bought it for use in my R2D tranny thats how he advertises it.(their noisy) and it made it sound like a watch. So when cleaning my axles one day I tried some there as well (RCP copper R/P noisy) now my rig is basically silent.
11-06-2008, 03:33 PM | #7 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i was thinking of using napa anti-seize grease that you get in the plastic grey bottle with the brush in the cap that's use to keep stuff on cars and trucks sliding and without nuts and bolts seizing...........bob .... |
11-06-2008, 03:48 PM | #8 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
| That is more or less for bolt. Objects that shouldn't move. Marine grade trailer bearing grease works really well. Thick, water resistant and very smooth.
11-06-2008, 05:31 PM | #9 |
Pebble Pounder Join Date: Jul 2008 Location: bedrock
i use quantum hot sauce oil and hot sauce grease for fishing reels,i got it to lube my bait casters,i got it from bass pro shops, good enough for high end fishing reels i think its good enough for my crawlers |
11-06-2008, 06:52 PM | #10 | |
11-06-2008, 06:56 PM | #11 |
Rock Stacker Join Date: Aug 2008 Location: Lincoln
| Never thought of that. I used to use it in my Mt bike years ago. Just make sure what ever you use it does not attack plastic. Some petroleum based grease will attack plastic. Last edited by tk5028; 11-06-2008 at 06:59 PM. |
11-06-2008, 07:32 PM | #12 |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
Local Bicycle shop has good grease. Pollylube is green and thick like the grease they put in your grears on the RTR
