08-22-2005, 09:41 PM | #1 |
Newbie Join Date: Aug 2005 Location: Roll TIDE Roll
| ALT. Battery for Nylint Jeep
The battery I have is from an older R/C. It is a 3000mAh 7.2V. If I can find a way to mount this battery (have some ideas) would it burn anything up? Pleas dont FLAME I am XTREMELY new to this and thought this cheapo would be a good start. Thanx, TheTrav |
08-22-2005, 10:17 PM | #2 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
Its 7.2 volt just like the stocker, if it's bigger than the stocker I wouldn't use it, if you cant mount it in the battery box it'll raise the COG and make the truck even more flip happy. It would probably quadruple your run time (stocker is 650 mah, I peak charge mine and get about an hour run time) though.
08-22-2005, 10:55 PM | #3 |
Thanx Trike......I just wanted to make sure I COULD. as for mounting the battery .........well I m gonn work on that TheTrav |
08-22-2005, 11:10 PM | #4 |
well, thinking about it, you could just whack some holes in the battery box and use it as kind of a cradle for the bat, make something to protect it and you'd be set.
08-22-2005, 11:27 PM | #5 |
Pebble Pounder Join Date: Jul 2005 Location: Mesa, arizona
if u have the jeep u can just use a stick pack and put it in the cockpit and zip tie it to the cage.
08-22-2005, 11:31 PM | #6 |
yeah but then you run into the high COG problem
08-22-2005, 11:34 PM | #7 |
well then go crazy and have lots of wires so u can solder a pack that mounts one cell on each corner of the truck and two on top of the cage.
08-23-2005, 06:44 AM | #8 |
Hell I ve already cut this thing to hell and ripped crap off of it. I was thinkin bout the battery cradle Idea, and Ive took the seats out and put the batery flat on the "floorboard" and the weight actually seemed to HELP. I m sure it changed my COG, but I dont believe it hurt it. I didnt flip off camber as much actually. Thanx for the Ideas and info guys, TheTrav |
08-23-2005, 10:10 AM | #9 |
hmm maybe this is the solution to people whining about stiff suspension then.
