Thread: Junk it or keep it?
Old 11-30-2008, 07:54 PM   #1
Default Junk it or keep it?
Ok ladies and gentlemen.....I got an original PTI Goliath in a trade with a buddie. Not sure what to do with it if anything? It seems ok for tooling around, but I like this crawler thing. I have a WK that is converted to a trail rig, Axial AX-10, and just bought a Cliff Climber! Is it worth putting money into the PTI, or should I just leave it stock?
pmikeyg is offline   Reply With Quote
Old 11-30-2008, 08:42 PM   #2
Depends... Is it worth it to you to have a PTI? You can probably still find a PTI at a comp, the axles can be beefed up and shimmed to last. It is going to take a little more work & money to set the axles up with metal diff gears or spools but it can be done. Why not make a trail rig out of it, the axles are narrower than TLT's, and with a little work the axles can be made strong enough for trail use.
jmz6 is offline   Reply With Quote
Old 11-30-2008, 10:47 PM   #3
Thats what I was thinking too. Trail rig takes less time and money! Any recommendations for axle parts?
Old 12-04-2008, 01:59 AM   #4
tc spools,shims,grind for steering.then beat till break.
thatguy is offline   Reply With Quote
Old 12-04-2008, 03:05 AM   #5
MWRCA'er
Mnster's Avatar
Scaler it...
Mnster is offline   Reply With Quote
Old 12-04-2008, 12:42 PM   #6
tc3/4 parts almost all fit in, so its easy to get parts @ the LHS. They work great for 1.9 sclaer axles, very compact design and if treated right they will hold out longer than most think.
jetboat is offline   Reply With Quote
Old 12-04-2008, 08:20 PM   #7
Scaler it is......
