Thread: PTI driveshaft help
Old 12-08-2008, 07:44 PM   #1
Default PTI driveshaft help
So yesterday I was out climbing some rocks and broke both rear lower links. I have replaced them with some beefy Traxxas links that are just slightly longer than stock. Once I got my pinion angle correct I found that my driveshaft is just a little too short.
Is there an easy fix or replacement for this? What are you guys doing that have modified the wheelbase?
Here are some pics..
Marc P is offline   Reply With Quote
Old 12-08-2008, 08:20 PM   #2
Default shorten
Shorten the lower links should solve it.
62 bugzilla is offline   Reply With Quote
Old 12-08-2008, 08:22 PM   #3
That would be the easy way....the stock lower links are just weak, I wanted to beef up the suspension a little.
Old 12-09-2008, 12:15 AM   #4
Default same
Keep the same strong links just shorten them allittle to get the cvd ti sit deeper in the stub axle. Also if you shorten the lowers allittle it will rotate the axle back to stock so it has less angle on the cvd. I upgraded mine to but kept the same length.
Old 12-09-2008, 06:45 AM   #5
How would I shorten these links??
Old 12-09-2008, 08:46 AM   #6
You can shorten them by unscrewing the ballends and cutting a few mm off each side. Screw a nut on before cutting so that it "rethreads" the link when you take it off.
You can also convert the CVD to Traxxas Maxx shafts. Search on here for the how to.
Skeeno is offline   Reply With Quote
Old 12-09-2008, 11:02 PM   #7
Did that tonight, had to dremel out the ballend a little to account for the beefy link, but it looks like the driveshaft is fine now.
