Thread: Cool custom build, the RCCAV
Old 11-11-2008, 10:00 PM   #1
R.I.P. Chip
jason's Avatar
Default Cool custom build, the RCCAV
I've been working on this project for a long time, but finally today just got it into the roller state.
R.C.C.A.V. RCCrawler Assault Vehicle. Stage 1 is just just the running vehicle, I should have that done here very shortly. Stage 2 will be a weapons system. This will consist of an airsoft gun, and a wireless video camera all operated by the radio.
Specs: 34 inches long, 23 inches wide, 8 inches tall, and nearly 70 pounds.
Gear: 6 RC4WD 40 series Rock crushers, 6 Axial 40 series beadlocks, 6 550 size motors, 6 planetary gearboxes, 2 17,000mah 12 volt batteries, 2 Castle Creations Monster Maxes, 1 Futaba 6EX 2.4ghz radio system.
The side chassis plates are all cut from 1/8" steel, the top, bottom, front and back are all 1/4" black delrin. The 2 pods are held together by 4 3/8" shank bolts into slotted holes to allow for articulation.
If my calculations are correct this 70lb beast should do right around 10MPH.
All I have left to do is to wire it and install the electronics and we'll see how it does. I am working with Northwest trac tech on some custom tire foams to be able to handle this amount of weight, and I am still second guessing my battery choice. I am thinking about maybe having some custom NIMH packs built instead.
Onto the pics.
jason is offline   Reply With Quote
Old 11-11-2008, 10:05 PM   #2
Diggin' the new SCX10 II!
badger's Avatar
Nice! I can't wait to get shot by this thing!
badger is offline   Reply With Quote
Old 11-11-2008, 10:06 PM   #3
thats just sick.
ROSS is offline   Reply With Quote
Old 11-11-2008, 10:06 PM   #4
I am not coming anywhere near you at Nats next year......
Rockcrawler is offline   Reply With Quote
Old 11-11-2008, 10:10 PM   #5
06 Super National Champ
JasonInAugusta's Avatar
Needs a Sentry system mounted on it. ;)
JasonInAugusta is offline   Reply With Quote
Old 11-11-2008, 10:13 PM   #6
[HOONIGAN]
Wrecker's Avatar
Good to see this finally taking shape!!!!
You think those hexes are going to hold up?
Wrecker is offline   Reply With Quote
Old 11-11-2008, 10:17 PM   #7
R.I.P. Chip
jason's Avatar
I got faith in the Axial beadlocks!
Here is another pic to give you some kind of size reference.
Old 11-11-2008, 10:24 PM   #8
Just wait till they program it to chase after you!
2JSC is offline   Reply With Quote
Old 11-11-2008, 10:26 PM   #9
basically its a tank with wheels instead of tracks
i like it and im anxious to see it when its finished, airsoft and all
gotta use the paint pellets though and make it fully automatic or its no fun
samb. is offline   Reply With Quote
Old 11-11-2008, 10:27 PM   #10
Let me rephrase this.......I am getting within radio range of you.
I think you are going to need to add about 16oz to the front, 8 in the centers and 4 in the rear.
Seriously man, thats going to be bad ass! Plenty of room to hold all the airsoft bb's too. Its bigger than I thought it was.
Old 11-11-2008, 10:40 PM   #11
Gettin’ back on the horse
Dang cranked that chassis out Jason! Aaron made it right?
TURTLE is offline   Reply With Quote
Old 11-11-2008, 10:43 PM   #12
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Nice to see this ready to rock! For plowing your driveway the lead acid will work well. For shooting things a lighter pack would certainly be nice. What voltage are you running it on? 12 or 24v?
JohnRobHolmes is offline   Reply With Quote
Old 11-11-2008, 10:49 PM   #13
R.I.P. Chip
jason's Avatar
Paintball sucks, too much of a mess. The sirsoft will be fully auto;)
Yea Aaron had the chassis cut out for me, he also tig'd the stiffeners to the chassis.
Gonna run it on 12V. These batteries will be ran parallel.
John I still haven't figured out how low I can run these batteries? Drive it till it won't drive then charge like a NiMH or do I need to set a low voltage cutoff?
Old 11-11-2008, 10:57 PM   #14
You would be best off to only use half of the battery capacity and then immediately recharge- this will make them last very long. Lead acid generallly doesn't like deep cycles. 10.8v is dead if I remember correctly. Somewhere around 12v should be half capacity, maybe a touch under that voltage.
Old 11-11-2008, 11:24 PM   #15
R.I.P. Chip
jason's Avatar
So I should be good if I set the cutoff on the Monster maxes to 12v?
Old 11-12-2008, 06:13 AM   #16
Yeah, as long as the batteries take the discharge asked of them. They should since you have so much capacity. I would be interested to see the amp draw of that sucker.
Old 11-12-2008, 08:35 AM   #17
R.I.P. Chip
jason's Avatar
The stall rating of each motor is 85 amps.
Old 11-12-2008, 08:36 AM   #18
You won't be stalling them at full throttle methinks. The batteries should take about 170 amps for a minute or two, 5c discharge rate.
Old 11-12-2008, 08:44 AM   #19
assault maddness. nice work.one big bad@$$ killing machine.
BILLYGOAT is offline   Reply With Quote
Old 11-12-2008, 08:46 AM   #20
R.I.P. Chip
jason's Avatar
Running this cool calculator I found here are some numbers for you John.
Torque required per motor to get it moving, 693 oz-in
Amps required per motor to get it moving, 17.412
Theoretical top speed 10.013
Total peak amps 104.47
Amp hours required to run for 5 minutes, 6.0942
Time to top speed, 1.49 seconds
Distance to top speed 15.879 feet
Effective pushing force 63 LBS
