08-23-2004, 10:57 PM | #1 |
Pebble Pounder Join Date: Apr 2004
| chassis dimensions
i am creating my first crawler and i was wondering- *how wide should my chassis plates be? *how long should my 4 link arms be? *how tall should my chassis plates be? *how long should the chassis plates be? i am gonna build a 4 link suspension mounted on 2 aluminum or steel parallel chassis plates also if u have any good pics that show good size and designs please post them |
08-23-2004, 11:01 PM | #2 |
| Re: chassis dimensions |
08-24-2004, 08:20 AM | #3 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
*how wide should my chassis plates be? 3-4in will fit most trannys *how long should my 4 link arms be? Definatly over 5in, but it really depends on the axles and wheel base *how tall should my chassis plates be? No taller than 5in *how long should the chassis plates be? No longer than 1 foot. These are my opinions, they are not garrenteed to work well |
08-24-2004, 09:27 AM | #4 |
how do u mount the shocks using cable ties or zip ties pics would be nice
08-24-2004, 07:10 PM | #5 | |
Pebble Pounder Join Date: Aug 2004 Location: Moab
| Re: chassis dimensions Quote:
As for your chassis Q's...are you going clod axles of are you going to be a 'shafty'? | |
08-24-2004, 08:41 PM | #6 |
Heres a rough picture of my chassis. I used carbon fiber for my chassis plates and each plate is 4" apart side to side. My links are 7 1/4" center of heim joint to center of heim joint. I'm using threaded Savage shocks mounted in this same position. I'm very happy with this so far. Makes for a little longer rig than most but I've always favored a little longer wheelbase,1:1 or scaled down. |
08-25-2004, 06:40 PM | #7 |
it is gonna be a clod axle crawler but how would u use locknuts to mount my shocks to the 4 links
08-25-2004, 07:44 PM | #8 |
use adel clamps. they're like the cable stays others are talking about but they are metal with a rubber liner, that will keep then from moving on the arms (links). |
08-28-2004, 05:50 PM | #9 |
where can i get those adel clamps
08-28-2004, 06:05 PM | #10 |
bendforthebone Join Date: Feb 2004 Location: Jamul
mines 8in long 3in wide and the bottom is 1 in long my links are 7in long
