Thread: Losi Crawler Shocks
Old 12-31-2008, 01:08 PM   #1
Default Losi Crawler Shocks
Do these things leak more than any other shock on the planet or did i get a bad batch. In droop they were only a little leaky. Switch them to sprung and i had 4 empty shocks both times i took it out to tesk them?
Culetto is offline   Reply With Quote
Old 12-31-2008, 01:57 PM   #2
mine leak alot too, i think it is a common problem. i just put 40 weight oil in and put teflon tape on the threads to see if it helps....
spinnrc is offline   Reply With Quote
Old 12-31-2008, 02:01 PM   #3
Sr. Product Developer
Rich Trujillo's Avatar
If you have the 2.2 shock set, then you need to crank down on the shock cartridge, they can not be hand tightened, you need to use a wrench or pliers.
If you are using the Mini Shock set, you should add the second set of seals that are included with the shocks.
Both these should solve your leaking issues
Rich Trujillo is offline   Reply With Quote
Old 12-31-2008, 03:43 PM   #4
Keep it real
Tanis's Avatar
From your title I assume you're talking about the 4" Crawler shocks. How did you build them?
Tanis is offline   Reply With Quote
Old 12-31-2008, 04:55 PM   #5
I had the same problem in less than a week i drained one and the others had a little left, so i filled them up and took pliers to end caps and havnt leaked since.
paintballer9876 is offline   Reply With Quote
Old 12-31-2008, 08:15 PM   #6
Thanks ill give that a shot. I like how smooth they are but i hate rebuilding shocks all the time.
They were built in the package.
Old 12-31-2008, 11:37 PM   #7
They are dif shocks but I put Teflon tread tape on my son's stock Wheely King shocks & it realy helped stoped the leaking. I want to get the Losi's for my rig I'm building, but I can't find them on Losi's web site. Were can I find these Things @, & do they come in crome.
Creepy Inc. is offline   Reply With Quote
Old 01-01-2009, 08:30 AM   #8
http://www.losipartshouse.com/servle...l?sfs=325382ae
Calderwood is offline   Reply With Quote
Old 01-01-2009, 12:52 PM   #9
Keep it real
Tanis's Avatar
I forget they are available in a kit now, I'm so used to piecing them together and having to build the seal cartridges. Sounds like you might know what the culprit is now
