08-24-2004, 11:23 PM | #1 |
Quarry Creeper Join Date: Aug 2004 Location: Southwestern PA
| How many of you run Independent 4 wheel steer?
Like the title says, how many of you run independent 4 wheel steer? If you do, what radio do you run? I run it on my clod and ran it on my jugg when I had it. I used a JrXr3 radio and it worked out perfectly. So what do you guys use? |
08-24-2004, 11:59 PM | #2 |
Pebble Pounder Join Date: Feb 2004 Location: Pittsburgh PA
| Re: How many of you run Independent 4 wheel steer?
just finished setting up mine with independent rear/front...as well as standard 4ws and 4 wheel crab steer Picked up a Hitec Laser 6 channel surface radio and used that for everything. Check out Clodtalk's product reviews area for the write up on how to put it in. Personally...after doing your course at MJ5 digger...i found that i really needed to have control of both axles independently if i wanted. Some areas are better navigated that way I'll never go back to the way i had it before lol... Matt |
08-25-2004, 12:09 AM | #3 |
I just put it on The Duke. I love it. For comps there is nothing better. I use a Traxxas TQ3 radio modified by soldering in a 3 position switch. Cheap and effective but not proportional. |
08-25-2004, 12:15 AM | #4 | |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
| Re: How many of you run Independent 4 wheel steer? Quote:
08-25-2004, 12:20 AM | #5 |
Quarry Creeper Join Date: Jun 2004 Location: aurora, CO
im running a JRR1 pcm with the auxilury switch programed for a three step sequence, and the tone is higher or lower depending on position, works nice and the switch is in a good spot
08-25-2004, 12:21 AM | #6 |
Explain? Explain what? Why Coors is the best? What I mean is when you flip the switch to turn the rear left or right all you get is full turn. No proportional like in the front where you can turn the tires a little bit or alot. It isnt a problem but its just different than the high dollar 3ch radios where you can have proportional rear steering. |
08-25-2004, 01:29 AM | #7 | |
Coors is laaame Had some of the stone brewery stuff tonight, its good times ;) | |
08-25-2004, 05:32 AM | #8 |
Pebble Pounder Join Date: Apr 2004 Location: Wollongong - Australia
I run a Hitec Agressor CRX. I have 5 seperate steering modes programed in. Good control, right price. I feel it would be impossible to win a comp without ind. steer now. Over here in Oz land I recon at least 70 - 80% of us have em in the comps. |
08-25-2004, 06:36 AM | #9 |
Moderator Join Date: Apr 2004 Location: In my head
I run fully independent 4 wheel steer with a Futaba T4VWD Attack 4-channel radio. I can turn the front or rear in any direction anywhere from full turn to just barely turned. The radio was around $119 for tower
08-25-2004, 09:06 AM | #10 |
Quarry Creeper Join Date: Feb 2004
Ya I run It also.It works great.I use Futaba FM ,and High Tor servos.
08-25-2004, 10:25 AM | #11 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
I run the Hitec Links 3D synthysized with 2 Hitec 945 MG's and love the control I have of the rear steer.
08-25-2004, 10:28 AM | #12 |
Rock Crawler Join Date: Jul 2004 Location: Mt.View CA
i have independant rear steer with a futaba skysport stick radio i like
08-25-2004, 12:42 PM | #13 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
I'd like too But my radio only has a two position 3rd channel switch. I have independent front and rear but rear is only one way. it sucks but it's better than no rear steer. |
08-25-2004, 01:06 PM | #14 | ||
08-25-2004, 01:22 PM | #15 |
Newbie Join Date: Jul 2004 Location: Germany
I drive my Flexx-Maxx with independent wheel steer. Got two Hitec HS-645MG and a Sanwa VG400, a 4-channel stick transmitter. The easiest way of control... ;) See it there: Klick! Manuel |
08-25-2004, 01:48 PM | #16 | |
bendforthebone Join Date: Feb 2004 Location: Jamul
08-25-2004, 02:49 PM | #17 |
Pebble Pounder Join Date: Jun 2004 Location: Trenton,Texas
anyone have a pic of the 4ws cuz i would like to see how cuz it would help me alot on turning with everything locked
08-25-2004, 06:57 PM | #18 | |
lost ya.. :? do you mean a pic of someone using 4ws? or the setup of independent 4ws?? lmk and i'll take pics lol Matt | |
08-25-2004, 07:37 PM | #19 |
I"m running a Futaba 3PM FM.
08-25-2004, 08:05 PM | #20 |
the setup cuz i wanna make my maxx 4ws with ifs and irs it will help me alot when get my front spool in
