01-31-2009, 11:58 AM | #1 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
| new build question
hi guys im putting a new super together with txt axles and a r2d trans what do you think the best motor and speed control would be to use |
02-01-2009, 08:53 AM | #2 |
well i guess i'll be the guiea pig than. |
02-01-2009, 01:58 PM | #3 |
Quarry Creeper Join Date: Feb 2008 Location: New Rochelle
well the best motor would be a puller 7t but that 80 bucks. Depending on the weight of you crawler i would do like a 55t. Since you are using the r2d it is geared really low so you will have tons of torque so that not a big issue. then i would also get a tekin frx or run a mamba max. If you use lipo youll gett a better run time.
02-01-2009, 08:58 PM | #4 |
hey thanks i'm thinking of going with a sidewinder and 3 cell lipo but not sure on the motor or pinion.
02-03-2009, 06:01 PM | #5 |
Rock Crawler Join Date: Jul 2007 Location: clearfield
IM not sure of the R2's gear ratio... but the TXT's are a 2:1... so, you might have to run some kind of gear reduction. i am running a GD600 (gear reduction) with a ratio of 3.8:1 on a txt trans with a ratio of 17:1 and i am running a 12t pinion on my motor... do the math and it is a 215.1:1 ratio... you probably didnt need the last part...but, i figured id toss some numbers out for ya. |
02-03-2009, 09:41 PM | #6 |
Pebble Pounder Join Date: May 2006 Location: Anaheim
I like brushless.
02-05-2009, 05:53 PM | #7 |
well i try 8 cell and a 50 turn with a 14 tooth and there just no power it wont even climb the wall. |
