02-07-2009, 09:58 PM | #1 |
| Shock Oil Difference?
I'm rebuilding my AX10 shocks, I went to grab for the shock oil and realized I have three different brands of the 30wt I am using, Traxxas, Axial, and Associated. Anyone know if there is any difference? Is one brand better, or are they all pretty much the same stuff? (Yes, I know the differences in the weights and what they do) |
02-07-2009, 10:42 PM | #2 |
Rock Crawler Join Date: Jun 2006 Location: Wisconsin
Shock oil is shock oil! If they are all pure silicone oil, then there shouldn't be any difference.
02-07-2009, 11:08 PM | #3 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
Yeah I would have to agree I have had all three and never seen a difference, not that I pay attention or even remember what I put in. |
02-08-2009, 09:37 AM | #4 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Rock Crawler Join Date: Dec 2007 Location: Dayton, Ohio
| Ultimate Shock Oil Comparison These are the charts we have been using in racing for a while, to compare the different ratings and oils on the market. __________________________________ Which manufacturer use which rating? Which manufacturers you can use same rating oil? Only manufacturers using Cts as rating are using a world standard and can be mixed used. Other ratings like W and WT differ from brand from brand as WT or is not a world standard!
For shock absorber use, this is the comparison table when using LOSI, ASSOCIATED and SERPENT some others silicone oil rated in "WT" "W" or are not labeled with a rating but just a number like 30/300
02-08-2009, 09:39 AM | #5 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
XRAY
KYOSHO
02-08-2009, 09:40 AM | #6 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ASSOCIATED
TRINITY
LOSI
02-08-2009, 09:44 AM | #7 | ||||||||||||||||||||||||||||||||||||||||||||||||
| SILICONE SHOCK OIL AND TEMPERATURE Although everybody thinks silicone oil is not affected by temperature, we can wake you up out of that dream. When the same test is done @ 10 or @ 30 degrees Celsius we get other values! Test result from our laboratory provid us with the following fist rule: Below some examples.
I hope this was helpful. - David | ||||||||||||||||||||||||||||||||||||||||||||||||
02-08-2009, 10:20 AM | #8 |
02-08-2009, 10:40 AM | #9 |
Rock Crawler Join Date: Dec 2007 Location: T1E Country
| So how does a "heavier" weight shock oil compare to a "lighter" weight oil on the effect of articulation? As the shock compresses will a heavier weight oil impede that compression? Or just slow it down? Can it limit the articulation? Thanks |
02-08-2009, 11:37 AM | #10 |
Quarry Creeper Join Date: Dec 2008 Location: fairfield
very informative. by far the best post concerning shock oil. thank you
02-08-2009, 11:51 AM | #11 | |
Imagine what its like sucking pop thru a straw vs a chocolate shake thru a straw. You cannot compress liquid. Shock oil will not limit articulation, only change the rate at which that motion is achieved. Last edited by Duuuuuuuude; 02-08-2009 at 11:54 AM. | |
02-08-2009, 11:56 AM | #12 |
Uh.... wow... Ok, so the simple answer is, yes, there is a difference. Nice info dkingston!!!! I know in 'go-fast' RCs shock oil gets heated a lot by the friction of the oil passing through the baffles, that heat changes the viscosity. In our slow motion, crawling trucks, does the shock oil really get hot enough to change the viscosity? RC Shocker: The heavier oil will slow down articulation and should not limit it. Anyone run different weights in the front than in the back? I have been thinking about going with the standard 30wt in the front, and 50-60wt in the back, to slow down the articulation of the back shocks. This should act like preloading the shocks to limit torque-twist, but would make the back suspension a bit more nimble. Last edited by Greatscott; 02-08-2009 at 12:00 PM. |
