Thread: Chassie Concept, Can a chassie be to skinny?
Old 02-12-2009, 12:06 AM   #1
Default Chassie Concept, Can a chassie be to skinny?
Hey guys, ive been readin quite a bit on chassie design, and people do like narrow, but is there such a concept do you think as To skinny?
i have a smithy 3 in 1 and have an idea how to build a chassie as narrow as you could hide the motor in it built for tlt axles, in other words building the tranny to fit
so my question is, can a chassie be to narrow?
Lorduss is offline   Reply With Quote
Old 02-12-2009, 12:16 AM   #2
If it is too narrow you will not be able to get the right triangulation of the upper links to make it stable. You could always use spacers on the outside of the chassis to mount the links to get some angle back. Try making one, who knows it might just be the next best thing. Way to think outside of the box.
moabax is offline   Reply With Quote
Old 02-12-2009, 06:38 AM   #3
I've tried one for a clod at 1" wide and didn't want to tinker with it anymore. Couldn't really get the whole setup to really mesh...but looked cool as hell.
the3kid is offline   Reply With Quote
Old 02-12-2009, 11:21 PM   #4
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
The benefits of a skinny chassis are a narrow contact patch at the bottom. I was trying to achieve that exact same thing when I designed the ARC. It has the narrowest skid of any chassis that I know of (for a competition 2.2), but it still give you plenty of upper link triangulation.
Check out the build here: Harley's "ARC" chassis build
Also another big thing is that you need room in the chassis for whatever equipment that is needed (trans or battery or whatever).
Harley is offline   Reply With Quote
Old 02-12-2009, 11:24 PM   #5
20K Club
Harley's Avatar
Also, I tried to design an Axial chassis as narrow as practical, about 2".
Old 02-14-2009, 04:28 PM   #6
Thanks for the advice guys, i guess the real problem (allthough not a problem realy) is getting the proper distance on upper links, everything else should be good. im inthe process of moving so this well take a bit
Harley, nice pics and info, is that molded or machined plastic i see inthose pictures? im interested in making some molded plastic parts....
very nice chassie, i like seeing your version
my whole concept evolves around the custom tranny, a chassie can only be as skinny as the tranny your able to fit in it realisticly.
no point in having a 1 inch wide chassie with a motor sticking off the side like a tumor
Old 02-14-2009, 05:57 PM   #7
true, but the motor has to go somewhere, and people don't like it up tp for center of gravity reasons.
I could almost see mounting an r2 on end, motor high, with chassis plates on either side of it. hmmm... something else to play with.
hairba11 is offline   Reply With Quote
