09-26-2005, 06:34 AM | #1 |
Newbie Join Date: Sep 2005 Location: melb austalia
| Aussy Gets nylint... and they rock
hey guys, i got my nylint crawler the other day from the states thanks to bugman72. so far i have had a rear diff problem but pulled the whole diff into quite a number of pieces and put it back together and it works normal again(woohoo) and i had used locktite before hand i have removed a control arm from the front and one from the rear, i have shaved the others alittle to clear diffs (worked on the rear, fronts not so much) i have removed a shock from the front and rear, removed the spring from the shock and inverted the shock, i have painted the roll bar and rims/beadlocks and the mickey thompson baja claw(on the tyre) but its all buffing off, but will be painted again some time soon. i have cut out the front gaurds, and cut the rear into a tray as i had to much flex scrubbing the body, it drives very very well, now here is some pics for you all cheers Dean http://www.outerlimits4x4.com/PHP_Mo...d.php?id=18625 http://www.outerlimits4x4.com/PHP_Mo...d.php?id=18624 http://www.outerlimits4x4.com/PHP_Mo...d.php?id=18623 http://www.outerlimits4x4.com/PHP_Mo...d.php?id=18628 http://www.outerlimits4x4.com/PHP_Mo...d.php?id=18627 http://www.outerlimits4x4.com/PHP_Mo...d.php?id=18626 http://www.outerlimits4x4.com/PHP_Mo...d.php?id=18630 http://www.outerlimits4x4.com/PHP_Mo...d.php?id=18629 |
09-26-2005, 06:51 AM | #2 |
Quarry Creeper Join Date: Aug 2005 Location: Jefferson City
I'm glad that you are enjoying it, Dean. The Jeep looks a bit different than it did when it left here!! Greg p.s. I sent the request for the other two for you. |
09-26-2005, 07:00 PM | #3 |
Newbie Join Date: Apr 2005 Location: Australia
i got mine before you deano so i like what you have done with it... And big thanks to Bugman for helpin us aussies out. Oh, and my nylint WILL be better than yours dean, i assure you! |
09-27-2005, 01:34 AM | #4 |
Newbie Join Date: Sep 2005 Location: australia
thanks you very much to bugman72, you sent me a scorpian for the record dean is a cheater, no shocks and half control arms so far mine has had cut and flipped tyres, rear axle reversal and wheel base extension, paint job, that about all i can think of atm, next up is going to be some bigger rubber for clearance! http://www.outerlimits4x4.com/PHP_Modules/phpBB2/download.php?id=18505 http://www.outerlimits4x4.com/PHP_Mo...d.php?id=18590 |
09-27-2005, 03:01 AM | #5 | |
you may have got urs first but mine crawled first and yours may out crawl mine but that does not mean with you behind the wheel it will and big bundy (greg) for the record i got shocks so many fingers Dean and one for the road to big bundy and dee201 Last edited by 45punkbus; 09-27-2005 at 03:04 AM. | |
09-27-2005, 03:32 AM | #6 |
its awwwn now....
