Thread: My Nylint 1/18 crawler
Old 10-09-2005, 04:50 PM   #1
Default My Nylint 1/18 crawler
So what can I do to get more flex out of my jeep? I've cut the springs and cut some of the bottom of the links so it they dont hit the axles. After this it still has the same amount of flex as it did out of the box.
Crawl-N-Clod is offline   Reply With Quote
Old 10-09-2005, 05:42 PM   #2
Extend the wheel base with the bic pen. Then remove the the rear shocks and replace them with limiting straps.
I could make the straps longer, but tires would hit the body. On the front I just cut the coils. This seems to work good for me. There are many other ways thou.
Old 10-09-2005, 07:00 PM   #3
Thanks for the reoly run2jeepn.... I'll give it a try.. on the staps what length are you using?
Old 10-10-2005, 01:28 AM   #4
Make sure you flip you flip your rear center link upside down. The frame will sit on it. My straps are maybe 2 in or a hair longer. Longer you make them the farther they will travel. If I made mine longer the tire would hit my tub. So if your's isn't cut off or dovetailed your chains can't be that long. You don't want your tires rub'n.....Just play with different lengths. Good Luck..
Old 10-10-2005, 09:55 AM   #5
Look around before you hack the heck outta things. There are alot of ideas on this forum to improve the performance of these things.
rerock is offline   Reply With Quote
Old 10-10-2005, 06:57 PM   #6
Ultimate RC Decals
BOWTIE's Avatar
inboarding the upper shock mounting location also helps.
BOWTIE is offline   Reply With Quote
Old 10-10-2005, 07:15 PM   #7
4 link that thing
Crawlsalot is offline   Reply With Quote
Old 10-10-2005, 08:02 PM   #8
Hey Crawl-N-Clod, notice you're from Newport? I'm from Batesville. I know we're supposed to be rivals but maybe we can get together and wheel sometime?
mstark is offline   Reply With Quote
