Thread: Sneek Peek, Thudertechs new axles
Old 09-20-2005, 11:54 PM   #1
R.I.P. Chip
jason's Avatar
Default Sneek Peek, Thudertechs new axles
Woohoo, I got my new Thundertech Racing Clodbuster CVD axles, just in time for the New NN chassis crawler I am building. I will be writing a full article on these axles, but couldn't wait to post these pictures.
These new axles come with all new bearings, as they are way to big to fit through the stock bearings on the clod.
Here is a picture of the shaft.
jason is offline   Reply With Quote
Old 09-20-2005, 11:56 PM   #2
R.I.P. Chip
jason's Avatar
Next, this pictures show my favorite part, the increased turning radius you gain from these axles. Top is a stock clod axle at full turn, bottom is a new Thundertech CVD at full turn.
Old 09-20-2005, 11:58 PM   #3
R.I.P. Chip
jason's Avatar
Here you can see the size the the new stub shaft. Note that these are also 1/4" longer to widen your clod 1/2" overall.
mmmm......beef......
Old 09-20-2005, 11:59 PM   #4
R.I.P. Chip
jason's Avatar
Here is the puny stock Clod outer shaft.
I believe these are shipping now, at http://www.thundertechracing.com/
Everyone but the Colorado guys can get them. I need the extra advantage of that steering
Old 09-21-2005, 12:46 PM   #5
slugzracing's Avatar
Yo are that bad a driver?
Looks very cool
slugzracing is offline   Reply With Quote
Old 09-21-2005, 12:57 PM   #6
Looks very cool
yes
DirkDigler is offline   Reply With Quote
Old 09-21-2005, 01:05 PM   #7
Originally Posted by DirkDigler
yes
SCORE! I actually have a chance at beating someone in a comp
Old 09-21-2005, 01:40 PM   #8
Well, he's not that bad.
Plays_with_Toys is offline   Reply With Quote
Old 09-21-2005, 08:46 PM   #9
The Wheels Keep Turning
kevinlongisland's Avatar
i also have them in stock and will be adding them to the store soon. got the package today.
jason, looks like you have the same dirt cheap digital calipers from harbor freight that i have. Great for the price!
kevinlongisland is offline   Reply With Quote
Old 09-22-2005, 04:27 AM   #10
Giggity giggity. Mine just ran out of batteries the other day. Don't know what I'd do with out them though.
Old 09-22-2005, 07:01 AM   #11
Order placed! Thanks Kevin.
-Jay
BigJay is offline   Reply With Quote
Old 09-22-2005, 05:51 PM   #12
-Jay
Thank you.
Old 09-22-2005, 06:01 PM   #13
my stockers turn more than that.until the knuckle hits the c hub.im worried about that pin snapping.ill wait a few months before i get them.
chafey is offline   Reply With Quote
Old 09-22-2005, 06:43 PM   #14
R.I.P. Chip
jason's Avatar
yea stockers turn till the knuckle hits the hub. To get the full advantage of these you have to grind the hell out of the knuckle ;)
Old 09-26-2005, 10:49 AM   #15
v33
good thing the knuckles are easier to replace than the hubs.
v33 is offline   Reply With Quote
Old 10-01-2005, 06:01 PM   #16
just a stupid question but, do these work in txt axles also? i dont see why they wouldnt but i figured i would ask...
wally187 is offline   Reply With Quote
Old 10-01-2005, 07:30 PM   #17
CSR
It's not a stupid question. It's actually one that needs answered, might save folks from wasting their money. The TTR axles WILL NOT work on a TXT.
The Clod and TXT use the same stock axle. It has splines on the differential end. On the TXT it slides right into the side gear in the differential. On the Clod it slides into a brass hex, which slides into the differential.
The TTR axle has no splines. It is hex shaped on the diff end. I haven't seen the actual product yet but in the CAD drawings it was hex shaped. I would assume it was since the new axle also comes with a new hex shaped piece for the diff.
CSR is offline   Reply With Quote
Old 10-01-2005, 08:50 PM   #18
06 Super National Champ
JasonInAugusta's Avatar
CSR is right.
Won't work on TXTs.
JasonInAugusta is offline   Reply With Quote
Old 10-01-2005, 10:44 PM   #19
well that sucks!!! does anybody make a heavier axle for a txt? i break them right at the cross pin like they are going out of stlye. not to hijack your thread...
Old 10-02-2005, 10:49 AM   #20
CSR
TXT owners might look at RC4WD's new Stainless Steel axle. Your turning radius would stay the same with the RC4WD axles, unlike the TTR Clod axles. :-( But the Stainless axles should be much stronger than stock axles.
http://rc4wd.com/shop/product_info.p...oducts_id=1113
