Thread: wall thickness of 3/8" tubing for 8-32 threaded rod
Old 04-03-2009, 07:40 AM   #1
Default wall thickness of 3/8" tubing for 8-32 threaded rod
I'm gonna be working with 8-32 threaded rod and 3/8" tubing. I would like the threaded rod to fit snug inside the tubing so what inside diameter do i aim for?
I have these options for inside diameter:
.245
.277
.305
.319
Thanks
Chris
muddeprived is offline   Reply With Quote
Old 04-03-2009, 07:47 AM   #2
8-32 rod is .158" dia.
PEDEcrawlerguy is offline   Reply With Quote
Old 04-03-2009, 07:57 AM   #3
I looked at some other options and it seems .235 is the smallest inside diameter I can achieve with 3/8 aluminum tubing. I guess that's better than nothing.
Old 04-03-2009, 10:43 PM   #4
Picky Fab'r/Acetal Junky
Offroader5's Avatar
The fractional equivalent drill bit for tapping 8-32 is 9/64"...so you'd need .140 ID or smaller to get it to work.
The .235 is almost 1/4"...so 8-32 thread would fall right through. Too large of an ID for 8-32.
Offroader5 is offline   Reply With Quote
