04-09-2009, 10:33 PM | #1 |
Pebble Pounder Join Date: Mar 2009 Location: Fremont
| s3r dig and spur question
Anyone with the s3r dig... can you grab your spur and check the end play for me? I seem to have some end play and do not think it is right. there is only a bearing inside the housing that goes on the spur shaft. So I don't know if this normal or not. Thanks. |
04-09-2009, 10:51 PM | #2 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
The tranny bearing set up is the same as stock. There should be two bearings on the spur shaft, and the other two also. There will be a tiny amount of play in an assembled unit.
04-09-2009, 11:00 PM | #3 |
thanks gunnar. we need to hook up and go crawling sometime.we are basically neighbors. |
04-09-2009, 11:16 PM | #4 |
If you can make it, get on over to the Concord Hobbytown on Saturday, crawlin 10am to 2pm, bring grimgard with ya.
04-09-2009, 11:22 PM | #5 |
Does there need to be a bearing on the spur shaft on the outside Of the housing? I have one on the inside but not the outside. I actually have a wedding to go to this sat. But I'm down any time. |
04-10-2009, 12:52 AM | #6 |
should be a bearing in the diff case(rear bearing, back of tranny case/dig) and a bearing in the front tranny case. Then a spacer over the front bearing, and then the pin for the spur gear mounting plate.
04-10-2009, 02:29 AM | #7 |
Like a boss... Join Date: Feb 2008 Location: NorCal
Also, I'd add if you have the slipper, there is even more play than without. There's several threads on here about this, you can shim it a bit to help but there is definitely some play on that top shaft with the slipper.
04-10-2009, 07:09 AM | #8 |
No slipper on mine. I have the bearings on the inside of the tranny case, on the outside is what I'm wondering about. It looks like there should be one there. I need pics. That reminds me, I was going to post up about mike and crew over at the concord hobby town. I will in a bit. |
04-10-2009, 10:39 AM | #9 |
It looks like a bearing could fit in there, but you use the spacer from your old tranny setup to put in there.
04-10-2009, 11:06 AM | #10 |
The spacer is a gun-metal color. But it does not fit in the new housing. I am pretty sure I am missing something, but do not know what it is.
04-10-2009, 12:25 PM | #11 |
I sent you an e-mail, you need to find P/N AX30489-spacer 5X6.9X4.8 That was the spacer I was talking about.
04-10-2009, 12:33 PM | #12 |
Got the email. Thank you so much. I hope I can find that part. That has to be the problem.
