09-09-2004, 12:19 AM | #1 |
RCC Addict Join Date: Jul 2004 Location: The other Crawler State
| Big truck Testers
I need 5 hard core big truck guys for some R&D. I am not looking for "Carnage Carl" that can bend an anval with a fly swatter either. I want 5 guys competing and who are running a GD-600 box. I want to test these. They will be free and will be sent to the guys I see or hear on here should diserve this freeby, post up. This could be good for all of us because I can't break one. Send a pm also if you want, thank you. The Dude. |
09-09-2004, 12:22 AM | #2 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
| Re: Big truck Testers
Hook me up man. PM'ed ya back too truck stats: TXT 1 55t Integy Lathe motor, 2.5 & 3.8:1 reduction options, 9t pinion, 7" assoc. BFT tires. Rock size? check the avatar. Final gear drive ratio freakin' LOW! |
09-09-2004, 12:28 AM | #3 |
Rock Crawler Join Date: Jan 2004 Location: Santa Cruz, CA
im good at braking things lol |
09-09-2004, 12:51 AM | #4 |
Oh I forgot, for those who posted just go back and edit. This is what I want to see. 1: type of truck. 2: size of tire 3: motor size and final gear eduction. 4: the total wieght of the truck with batteries and body's if you have them. I'll even take a tuber if it competes alot. Field testing will count also if you go big rocks, like wich one isn't. I will pick the five and you will recieve a pm. Thanks again. |
09-09-2004, 01:01 AM | #5 |
all the norcal crawler guys crawl some of the biggest, rocks youll see. seascape is just giant. I myself dont need it because im allready running a gd600 with turned down shaft. they work well |
09-09-2004, 01:15 AM | #6 |
I'll test... I run in comps.... I have big truck... |
09-09-2004, 07:52 PM | #7 |
O.K. I'd like to know. I don't run a GD-600,never have seen one hands on,all I know is that it's a type of reduction box for RC's. I wouldn't mind getting some kind of reduction box someday. This part your wanting to test,what exactly does it do for the GD-600? Does it gear it down more,make it stronger,whats the scoop? Just wanting to learn a little. If I get a reduction box someday I'd like to know so I can get one that has different options or can be upgraded or made stronger if the need arises.
09-09-2004, 08:04 PM | #8 | |
RCC Addict Join Date: Jun 2004 Location: SERCRC
| Re: Big truck Testers Quote:
-Losi LST tires on narrowed wheels (~7") -Stock motor or sometimes a 19 turn double, final ratio with 2.5:1 GD-600 is 85:1 -last time I hung it on the scale it was 11 lbs. Currently I'm running a 15T pinion with the hole bored out to fit the GD-600. | |
09-09-2004, 08:38 PM | #9 | |
I'm guessing the modified shafts will not be the weak link. The reduction unit is at the front end of the torque multiplication. I may be proven wrong, but I don't think there is a motor stout enough to twist off a turned GD-600 shaft. 8O | |
09-09-2004, 08:44 PM | #10 |
Quarry Creeper Join Date: Apr 2004 Location: Louisiana
Here is a picture of the orginal shaft and reduction unit. |
09-09-2004, 08:58 PM | #11 | |
Pics no worky :( Here's a little tech write-up I did on installing a GD-600 in a TXT, included is picture of the unit that I robbed from Tower's website. The aluminum propellor mount slides off after loosening one set screw. http://www.rccrawler.com/postlite1943-gd600.html | |
09-09-2004, 09:11 PM | #12 | |
09-09-2004, 09:48 PM | #13 | ||
Thanks for explaining that. The theary on the hardening is right, but unless you have machined anything, I am not going to go into "machine hardening". google it please. If you don't understand it then don't feel bad. I have been a steel fabricator for 20+ years, 15 of that high end and prototype. I am all self taught and now a thing or too. The best thing would be a porpose built tranny. It is spinning in my head right now. | ||
09-09-2004, 10:08 PM | #14 | |
I tried studying up on metallurgy, cryogenics, and tempering once..... too much info, made my brain hurt and swell, which eventually pushed out most of my hair. 8O | |
09-09-2004, 10:51 PM | #15 | |
[quote="CSR"] Quote:
BTW: this is not a first five post up thing. This is a best of 5 interviewed thru PM. Thank you, the DUDE. | |
09-10-2004, 08:53 PM | #16 |
I need more guys to post up. I have three for shure and would like to here from some from all over the US that is RC crawling. Thanks Dude. |
09-10-2004, 09:02 PM | #17 |
Rock Crawler Join Date: Jul 2004 Location: Mt.View CA
i will test it i got a [b]txt-1 gd600 reduction stock motors 9t pinion gears i will be runnning in comps that the NORCAL RCRC have i also am putting a comp on right now and there should be a comp every month i would be glad to test it for you thanks BIGRED
09-10-2004, 10:23 PM | #18 |
Pebble Pounder Join Date: May 2004 Location: Portland or
Hey dude, Sounds as if I will be seeing you soon, I am Sean I work with toyo on all of the orcrc and rcrockgear stuff. I would love to try your shaft (hehehehehe). I have several trucks. I think a good test rig would be the twin force though. Twin axles four linked twin tranny running a european inline gear reduction but have access to gd6'S cut narrowed kongs on custom offset savage wheels. Batts mounted on front axle. Truck is incredible has only been done for a few weeks but has made things that my maxx crawlers and tlt cannot even think about going up look easy. I am in Portland and dont check my pm too often so email me if possible. wrxsean@hotmail.com Hope to hear from you soon..... Oh you can see it in our pics in get togethers here. Narrowed landcruiser body Sean |
09-12-2004, 12:54 AM | #19 |
I need one more tester, here is the list so far' DirkDigler rckjeep wheels bigred Hackster and Toyo you will see one real soon so, that said, I need someone else on the line with these guys, thier huge(tires). Dirk runs the big stuff too and knows a thing or two. Thats kind of what I am looking for. The shafts will go at the end of the week. I am not taking orders and don't know if I will. This is a test. |
09-15-2004, 08:33 PM | #20 |
DirkDigler rckjeep wheels bigred Well thats looks like thats it I am spinning up shaft as I type, sorry I was trying before Mohab but between a wifes birthday and my daytime job caous I got alittle behind. I haven't had the time to look for all addy's to send so send the mailing adress with a first name. I am off to work now, If I can get a couple done tonight I will post up. These will be for the guy's going to Mohab first and I am doing all between the next two days. Thank again Dude. |
