10-19-2005, 07:28 AM | #1 |
Newbie Join Date: Aug 2005 Location: Southern Maine
| Flex Question *Pics*
Hey guys, my gecko pro chassis just came in and I've got a couple questions... Does the "flex" or "articulation" come from the slop in the links? I labeled it in this picture: Because one side gets a lot more flex than the other, illustrated here: compared to this: It seems like its binding somewhere... Is this something to worry about? How can I fix it if i need to? |
10-19-2005, 07:46 AM | #2 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
Wait till you get your axles and shocks on because that will determine your articulation. I would double check the ends to make sure they don't have any debris or burrs in them. |
10-19-2005, 07:54 AM | #3 | |
But im right with my thinking that the flex comes from the slop in the links right? | |
10-19-2005, 08:13 AM | #4 | |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Jay | |
10-19-2005, 02:44 PM | #5 |
So do u guys think i should try and find the source of limiting flex on that one side or does it not really matter?
10-19-2005, 02:55 PM | #6 |
Pebble Pounder Join Date: Aug 2005 Location: Kenosha
antoher thing you should check is the hiem joints on our links. if one link has miss-alinged hiems, then i can see that messing up your flex.
10-19-2005, 02:57 PM | #7 |
What are hiems, i think you're on to something...
10-19-2005, 03:04 PM | #8 |
Pebble Pounder Join Date: Sep 2005 Location: Rapid City
He's talking about the joints. 1:1 rigs use heims, so thats what they're like. Since the mounts are parallel, the rod ends should be parallel to each other as well. Last edited by bobbo27; 10-19-2005 at 03:09 PM. |
10-19-2005, 03:12 PM | #9 |
Try unscrewing one of the ball joints a half turn, or whole turn.
10-19-2005, 03:13 PM | #10 |
Ok, thats what i think is wrong, i think one of the rod ends are turned a little farther than it should be. Thanks.
