Thread: 9.6 volt battery swap?
Old 01-18-2006, 12:03 AM   #1
Default 9.6 volt battery swap?
Can we use 9.6 volt battery packs in our 1/18th crawlers instead of the 7.2 volt. i know on the rockcrawler 1/10 jeep, each motor is made to handlle the full voltage of the battery pack so as long as you dont double it you are fine. i ran mine today with the 9.6v for like two minutes at about half charge on the battery and no problems, i searched but couldnt find anything on this. thanks kevin
stx4wheeler is offline   Reply With Quote
Old 01-18-2006, 12:49 AM   #2
you can run it on the 1:18th no problem, but all it does is make it go faster. I ran a 9.6v on one of mine once because I was running a heavy die cast body,but it was still too fast in my opinion. just my .02 cents.
madzuki is offline   Reply With Quote
Old 01-18-2006, 01:37 AM   #3
Run the 9.6v and do the extra low gear Mod. Perfect. Extra power and Lower gears. Can you say spinning 2.2's 3 times fast. ( Well maybe not spinning )
