Thread: My Scorpion MK1... kind of...
Old 06-23-2009, 08:09 PM   #1
Default My Scorpion MK1... kind of...
I built this tuber about two years ago and finally upgraded the suspension to forced articulation/active suspension. I have spent many hours searching this forum and this is what I have come up with... so thanks guys!
Here are the specs:
WB - 12 3/8"
Axles - TLT
Tranny - Stealth 2.65 w/custom dig
Motor - usually an HH 30t Torquemaster, but waiting on a new armature, so for now a Reedy 19t
ESC - Sidewinder + CC BEC
Tires - Losi comp claws
Servo - Towerpro 946
Here are a few pics... hope they show up and the right size.
This is my first attempt at a tube chassis and brazing.
Bottom view, you can see the swing arms attached by inline ball joints.
Here you can see the forced articulation at work. I compressed the rear left and the front right came off the ground. Also, you can see the cantilevers at work in the rear.
Here is a close up of the cantilevers articulated. Had to install one shock on the left side to eliminate torque twist. Works great.
Here is a top view that shows the parallel linkages front to rear. Also my home brew dig lever. With this suspension setup there is hardly any body roll, which is awesome on an off camber.
After a lot of fine tuning on the rear to eliminate torque twist this setup works well on my backyard rock course.
Fish is offline   Reply With Quote
Old 06-23-2009, 09:04 PM   #2
Do you get much side play with the in-line ball joints on the lowers ?- Neat idea !
ClodNutz is offline   Reply With Quote
Old 06-24-2009, 04:47 AM   #3
No side play but there is a rubber disk for a cushion in the base that gives about .020" end play.
Old 06-24-2009, 02:56 PM   #4
Here is a short video of the suspension being flexed manually.
I will post a video on the rocks as soon as it uploads.
http://www.youtube.com/watch?v=26J3VOQSVdE
Old 06-24-2009, 06:57 PM   #5
Here is a short video on the rocks.
http://www.youtube.com/watch?v=Cz5lGiT1BYM
Old 06-24-2009, 08:11 PM   #6
Nice!
Looks like it crawls well too.
Rockcrawler is offline   Reply With Quote
Old 06-24-2009, 10:00 PM   #7
That thing is a beast. Great work
Gordie
gordieb is offline   Reply With Quote
Old 06-25-2009, 09:57 PM   #8
Here is a video of the full course... shows my lack of driving skill.
http://www.youtube.com/watch?v=cFswCJKqh1I
Old 06-25-2009, 10:30 PM   #9
That thing is very Madd Maxx-ish, looks like some crazy apocalyptic machine...I like it
slimeball is offline   Reply With Quote
