Thread: Rear Steer axle
Old 07-23-2009, 09:51 PM   #1
Default Rear Steer axle
Can anyone help,thought I had seen a thread in the past about building a rear steer axle.Or any tips on building one for my ax10 would be great.Ordered 3 channel radio thanks to all your help,any thoughts on a servo??All of your help is much appreciated.
Rocksaurus is offline   Reply With Quote
Old 07-23-2009, 10:26 PM   #2
I think the AX10 axles are the same just the rear has strait adapters. May havve strait axles inside. What you need is the axle (if you have the strait ones), Cs and knucles for the front and take off the strait adapters and install.
lt1zwb96 is offline   Reply With Quote
Old 07-23-2009, 11:52 PM   #3
you dont need a 3 channel tx if you put a y harness on
kalin96 is offline   Reply With Quote
Old 07-25-2009, 09:59 PM   #4
you just have to mirror the front axle. the same servo you have on the front wil work. something like a hitech hs645 would be fine. axial sells a rear steer kit. you can link the servos with a y harness and not need 3 channels. you can't run a comp with rear steer though, you would be better using your 3rd channel for a dig to get better turning radius. then you would still be comp legal
datablitz is offline   Reply With Quote
Old 07-25-2009, 10:02 PM   #5
i could be wrong but i think a y-harness will make it crab walk!
jamesdicken is offline   Reply With Quote
Old 07-25-2009, 10:17 PM   #6
depends on how you mount the servo. if it crab walks you can flip the servo over on the mount and switch your link to the other side. or you can get a reversing y if you have that problem.
Old 07-25-2009, 10:34 PM   #7
is there such a thing?
Old 07-25-2009, 10:43 PM   #8
Yep sure is. You can search on tower hobbies or horizon and find them. Larger lhs should have
them too
Old 07-25-2009, 10:47 PM   #9
nice
Old 07-25-2009, 11:12 PM   #10
Thanks all of you for your help and input.No comps just a whole lot of freakin fun.:-P This site is awesome.
Old 07-26-2009, 08:05 AM   #11
the reversing y's also normally have an adjustment to help you center the second servo to trim out the rear
Old 07-26-2009, 09:15 AM   #12
that would be sick for a super.
