11-14-2005, 09:11 AM | #1 |
Newbie Join Date: Nov 2005 Location: Chraolotte
| Front Drive O-ring part # on 1/6th for those interested.
Part # 8d35817926- this is a 1- 13/16 O-ring purchased from Advanced Auto Parts. They are plentiful in most communities. Its a tad smaller than stock belt, but not so much so to overwelm electronics. grips good. This is for the front.
11-14-2005, 10:38 AM | #2 |
RCC Addict Join Date: Aug 2005 Location: Akron
thank you sir got a price with that? |
11-14-2005, 10:59 AM | #3 |
67 Cents, Tax Included. I hope I gave the correct Part Number, its the number listed by the bar code on the bottom of the package, None the less you should be able to locate it with that number.
11-21-2005, 10:32 PM | #4 |
Pebble Pounder Join Date: Nov 2005 Location: South Range
And what is tax in Charolette NC? lol Thanks for the tip!
01-07-2006, 01:36 PM | #5 |
Quarry Creeper Join Date: Dec 2005 Location: Mechanicsville, VA
I jut picked up mine today and the # you have listed is not only NOT the part #, but it's also different than what's on my back. The # you listed is the skew #, and mine reads 8035817924 At least, that's what the guy at Advanced told me. Just thought I'd post a heads up... |
01-07-2006, 01:43 PM | #6 |
Newbie Join Date: Dec 2005 Location: Nashville
beeeeeeeeee careful. I tried one awhile back and it put so much stress on the axle i broke it on both sides. I'll take pics of it if you dont believe me lol. Thay work well until that happens though. They also have a size for the back too. Same thing happened back there though.
01-12-2006, 05:52 AM | #7 |
In the first post, I stated it was for the front only, In my next post I stated I was unsure if that was a part number, so a skew number could be correct.
01-12-2006, 09:06 AM | #8 |
Pebble Pounder Join Date: Dec 2005 Location: Fort Worth! Need a Address??
i have had better luck with a o-ring in the front and front belt in the rear. I put a o-ring in the rear and 30 minutes later i busted it. The rear grips really well and can get axle wrap. I think cause of weight dist. that an oring in the rear is to much stress with no play.
01-18-2006, 07:47 PM | #9 | |
Pebble Pounder Join Date: Nov 2005 Location: Orlando
All you need is a hobby knife and some CA. The belts are made of Buta-N (nitrile) if you cut approx 9.6mm off the rear belt and use a small drop of CA to reglue it, you will have a slighlty smaller belt and it will stop the rear slippage. | |
02-05-2006, 08:49 AM | #10 |
Pebble Pounder Join Date: Jan 2006 Location: hartford
| ca glue
what type of glue is it and where can you get it
02-05-2006, 02:08 PM | #11 |
Rock Stacker Join Date: Jan 2006 Location: On the rocks...
CA! 'superglue'! Available at your local hobby shop. ...ok, everywhere ELSE, too...I was just promoting hobby shops! |
04-06-2006, 08:48 AM | #12 |
Rock Stacker Join Date: Jun 2005 Location: usa
so super glue works as ca glue is it the same strenth
04-07-2006, 10:09 PM | #13 |
Newbie Join Date: Apr 2006 Location: Midwest
so i have heard of spraying belt dressing on it how does that work if i just put one small spary on the pullies if not what is the best oring to use for the front and what is the best for the rear? |
05-03-2006, 12:16 PM | #14 |
Newbie Join Date: May 2006 Location: binghamton
| rear drive belt...
hello, i am VRY new here and to rc's.....there was mention of a o-ring being try'd, well my rearend was slipp'n the belt, so i went to my local t.v./vcr repair shop. (been there b4 for vcr belts) and remember the kazillian differant sizes he had on the wall-HMMMMMMMMMMMM... he hook me up w/ a belt that fits awesum... it is (SBL) square belt lenght 6.7, alittle pricey for what it is,($6.50), but if'n it keeps sumthing else from break'n its wurth it in my eye ...
05-03-2006, 02:33 PM | #15 |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
for those of you wondering if plain ol superglue will work, i just took an old vacuum cleaner belt and cut it.....then i glued it back together with Loctite Brush On Super Glue and i cant get it to pull apart
05-06-2006, 11:36 AM | #16 |
Rock Stacker Join Date: Apr 2005 Location: Queens, NYC
I just picked up an O-Ring from Advance and the back of the package reads th following: 64133.1 1-13/16 x 2 x 3/32 O-RING 0 80358 17926 9 Here's a pic: http://www.fuel****.net/hosting/uplo...vanceoring.JPG Note: replace **** in link with s l u t (darn werd filters) I installed the O-Ring up front and then installed the front belt out back.... Now it runs better than ever!! Gunna pick up another o-ring and do the same to my other Scorpion.... Rick |
05-06-2006, 01:37 PM | #17 |
thanks for the info snakeeater, no i know EXACTLY what size to look for..... im going to pick up a couple o-rings for the front and put the front belt in the back......will probably shorten the stock rear belt for a backup |
05-17-2006, 08:29 AM | #18 |
Rock Stacker Join Date: May 2006 Location: Rome
| nylint crawler
i put the o ring on the front and front belt on the back it works really well in low but when i put in high it cuts on and off is there to much stress on the electronics could it be the circut on the battery can i take the circut off with out hurting any thing |
05-17-2006, 08:32 AM | #19 |
Quarry Creeper Join Date: Apr 2006 Location: winchester
and your sure that you dont have a dead battery, or that your switch is mounted wrong if a tummy tuck has been done. |
05-17-2006, 08:36 AM | #20 |
the battery just came off the charger charged it for 12 hrs no tummy tuck yet
