08-12-2009, 02:49 PM | #1 |
Pebble Pounder Join Date: Jun 2009 Location: Jackson
| Why Delrin?
I plan on making my own links, and I see how popular it is, but I was planning on going with stainless steel. Definitely don't want aluminum because it is to sticky on the rocks, but is Delrin slicker than stainless? Is it just a cost issue? |
08-12-2009, 03:43 PM | #2 |
Delrin is very slippery; especially compared to aluminum or stainless. I'm pretty sure it's cheaper than stainless as well and easier to work with. Not as strong though, which is why you see delrin links that have alot of extra beef like the Kamikaze Kustoms links or standard round links that are like 5/8" in diameter... |
08-12-2009, 06:43 PM | #3 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
5/8" I need to see a picture of this rig. 5/16" round solid Delrin makes a great link for a 2.2 |
08-12-2009, 07:13 PM | #4 |
Quarry Creeper Join Date: May 2005 Location: Auburn
Yeah, stainless hollow rod for say revo links and threaded rod is like 8$ for 12" at ace/lhc (might be cheaper on the net etc) Cutting, bending, drilling, and then tapping solid stainless is something I wouldnt want to experience. I'd like to find say delrin thin enough to slide over my alum links. (haven't tried the BIC pen thing though) |
08-12-2009, 07:19 PM | #5 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
I prefer stainless actually. It doesn't seem to get as rough in any amount of time; I've been running the same ss links for almost a year and they haven't gotten any less slick on the rocks. The same can't be said for my delrin skidplate, I've had to sand it down a few times.
08-12-2009, 07:19 PM | #6 |
Quarry Creeper Join Date: Apr 2009 Location: Ukiah
I just put a delrin skid on my stock Axial chassis and it's slick as snot. Slides 10X better than the stock plastic one. Just got my R2J Kustoms 3/8" delrin links to use on my SWX. If they slide like the skid I will be a happy camper. |
08-12-2009, 08:06 PM | #7 |
I was planning on using the stainless rod with the 8-32 all thread.
08-12-2009, 09:04 PM | #8 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
08-13-2009, 09:16 AM | #9 |
Quarry Creeper Join Date: Mar 2009 Location: Torrance, CA
Delrin is cheap and easy to work with. I'm making SS links. Thought about making tool steel links and having them heat treated and nitrided too.
08-13-2009, 09:35 AM | #10 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
I run straight 1/4" Delrin lowers in front and bent 1/4" stainless lowers in back. The Delrin flexes too much in back for me. My rear links are about an inch longer than the fronts. I also run a Lexan skid in the rear, so the links don't contact the rocks much. |
08-13-2009, 02:08 PM | #11 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
1/4" was fine on my comp 1.9 but I'd never run it as lowers on my 2.2 I'm running downtown's lower derlin links on my 2.2, Last links I will buy for it. |
08-13-2009, 02:38 PM | #12 |
It depends on the construction of the acetal link. If you use solid acetal rod, then it needs to be a larger diameter material so it doesn't bend all over the place. This is why you see 5/16", 3/8", and even 7/16" acetal links...because they are more likely than not a solid rod. You couldn't get away with using 1/4" solid rod on any links longer than say 2 inches. It would just flex way too much. 5/16" is a MINIMUM if using solid rod. On the other hand, if you use acetal tube, you can get away with a much smaller diameter. I use 1/4" diameter acetal tube for almost all my links. I run 8-32 or M4 all thread down the center of the tube (as a slip fit) end to end and then thread on the Revo ends. This gives me a small diameter link so it doesn't look so out of scale, but still allows for the slipperyness of the acetal as a coating. The threaded rod down the center stiffens up the smaller diameter acetal so that it's really strong. Stainless is a bit more of a pain to work with and could be more expensive depending on where you source it. It is still a good choice for the rocks since it's a bit harder than standard mild steel and doesn't gouge much. Takes alot of abuse. |
