09-05-2009, 06:55 PM | #1 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
| gear calculation question
I'm looking at buying the RC4WD 2spd tranny and i was wondering if some of you know how to calculate the reduction with different size pinions. its listed on its site as..... 6.7:1 (with 8 tooth pinion gear) or 11.4:1 (with 8 tooth pinion gear) also states it is 8-20 tooth compatible |
09-05-2009, 08:02 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
devide the # of teeth on the spur gear by the number of teeth on the pinion.. example: 87t spur devide by 14t pinion = 6.2 :1 reduction but in this case you would have to know the #of teeth on the hi and low gears.. so lets say high is 50teeth and low is 87 devide those by the size of pinion you use |
09-05-2009, 08:56 PM | #3 |
i would think that would be the case if it were a two gear transmission like a rear end. transmissions use multiple gears which is why i don't know how to adjust the calculation from an 8 tooth pinion to a 20 tooth
09-05-2009, 09:03 PM | #4 |
Quarry Creeper Join Date: May 2004 Location: SW of Chicago
If you have a known ratio, 6.7:1 with a known pinion, 8T, multiply the 2 together then divide by the pinion you wish to change to. (internal gears don't matter because you have a known ratio) 6.7x8=53.6 change to a 10T 53.6 / 10 = 5.36:1 or 20T = 2.68 11.4x8=91.2 / 10 = 9.12:1 or 20T = 4.56 Last edited by ThunderVP; 09-05-2009 at 09:07 PM. |
09-05-2009, 09:09 PM | #5 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
Half way down this posting, someone talked through the different ratios: http://www.rc4wdforum.com/showthread.php?t=8065 Also, PM "greasypete" He posted that RC4WD had sent him the info. |
09-06-2009, 10:25 AM | #6 | |
wow thanks alot | |
09-06-2009, 10:27 AM | #7 | |
thanks also | |
09-06-2009, 01:44 PM | #8 |
Pebble Pounder Join Date: Jan 2009 Location: Yacolt, wa
good info
