09-30-2004, 09:45 AM | #1 |
Quarry Creeper Join Date: Feb 2004
| Clod Axles 2 Shaft Drive?
Anyone Ever Tried this?I really Hate how The Clod Motors Stall out when ya need the Power.So I was thinking of making a Shafty out of them .I really like my TLT-10 But I want a Bigger scale Crawler also.and no one wants 2 by the Clod so I can buy the parts 2 biuld a shafty so...I came up with this.Any Imput?
09-30-2004, 10:23 AM | #2 |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
| Re: Clod Axles 2 Shaft Drive?
You could mount a center diff to the input. But it would be silly to do that, you'd be taking the advantages of a clod, and be making a really heavy shafty with TONS of parts to break. Clods have the weight down low because of the motors, if you put a tranny and motors up there, you're ruining it. Not to mention it would be so much work that it would just be silly. And whatever reasons you like your clod would be ruined when you made it a shafty. It would just be a narrow, heavy shafty, with no ground clearance. Lay off the pipe |
09-30-2004, 03:18 PM | #3 |
Hey It was a Idea .No Shit the Clod has the Motors down low .Ive had this Clod for 11 years.It been a Crawler for the Last 5 .Dont be a Smart Ass!
09-30-2004, 03:58 PM | #4 |
Rock Crawler Join Date: Mar 2004 Location: Where it's wet
I'm not sure exactly what you are talking about Bigbad, but roktoy turned out a really cool piece a while back... Go Here for the pics! I think this would be the perfect beginning of "dropped" axles for better diff clearance... |
09-30-2004, 04:39 PM | #5 |
WOW! Thats Really Nice !I bet that would work really well with some TLT axels.I have a Couple new clod axles Im going 2 have to do that 2.
09-30-2004, 06:10 PM | #6 | |
| Re: Clod Axles 2 Shaft Drive? Quote:
EDIT: can you post the pics here? I'm not a member of that site, and I don't want to become one. | |
09-30-2004, 07:14 PM | #7 |
| Re: Clod Axles 2 Shaft Drive? Beautiful work here. I believe he was contemplating a shafty rig with this as the center trans. With the clod trans you could get some pretty low gearing without too much extra hardware... |
09-30-2004, 09:17 PM | #8 |
Hah! I thought of doing something JUST like that, only putting dogbones there and making an angled clod axle |
10-01-2004, 01:54 AM | #9 |
Pebble Pounder Join Date: Apr 2004
it looks sweet, what would be final gear ratio with clod axle?? How much would something like this cost??
10-01-2004, 09:16 AM | #10 |
If ya dont have a Machine shop u can Just cut the plastic out puts and the axle 2 size.it would't cost anything but time.The Aluminum parts look Awesome tho. Hey everyones a Smart ass now and then.
10-01-2004, 10:48 AM | #11 |
...I don't think it would be quite that easy.... I believe it would require 2 bearings on each side to keep the axle from wobbling. If you only have 1 per side then I'll bet your gears would get crunched... Easy way to test would be to remove your knuckles and the outer bearing and spin it with some side-to-side torque to see if you hear bad things inside the case...
10-02-2004, 12:58 PM | #12 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
Dude, what Roktoy built and what whitey are talking about are 2 different things. The pictured clod contraption that Roktoy built is a TRANSMISSION. Not an axle. It's like a emaxx transmission, but built from a clod gearbox. You would still need front and rear axles/differentials. What whitey wants to do is convert a stock clod axle to accept a drive shaft from a regular transmission instead of the axle mounted motor. |
10-02-2004, 04:39 PM | #13 |
You got it.I just have a few clod axles so I wanted to build something different.Maybe a Clod axle/Trans and Clod axles into Shaft drive.Or maybe I'll just Use e-maxx axles and the Clod Trans.Winters comming so...I got some time to Build.I allready have a TLT with a Blackfoot Gear box modified as the center Trans.Now I need a bigger scale Crawler.
10-02-2004, 04:51 PM | #14 |
bendforthebone Join Date: Feb 2004 Location: Jamul
that is so cool
