10-21-2009, 03:48 AM | #1 |
Pebble Pounder Join Date: Jul 2007 Location: little rock
| shock length and travel
i need to know the extended and compression from eye to eye of rc4wd scale dual spring shocks??
10-21-2009, 07:58 AM | #2 |
Pebble Pounder Join Date: Sep 2009 Location: tulsa oklahoma
Looks like they sale 80mm, 90mm, 100mm, and 110mm. The travel amount is gonna depend on which one u choose.. If you look at some of their scale shocks that are Internal sprung, there is dimensions on them ..the 100mm has 23mm of travel.. I would say the externally sprung shock has slighy more travel..most other shocks at 100mm seem to have 29mm of travel.. I don't have facts but I'd say the 100mm rc4wd dual spring scale shock has about 25mm travel..plus or minus a couple mm Last edited by slam49; 10-21-2009 at 08:15 AM. |
10-21-2009, 02:22 PM | #3 |
ok humm ill have to contact rc4wd then lol. there for my build and i wanna make sure i get what i need lol.
10-21-2009, 03:38 PM | #4 |
Well, you'll need to know what lenght shocks you need before you call them most likely.. Did you measure it.. At ride height, measure from the upper mount to the lower mount. That will be your extended lenght.. When they Advertise the shock being 80, 90, or 100mm ect. That is the extended length.. Just for a little extra help if you have a limited supply of measuring tools, 25.4mm equals 1 inch, so a 100mm shock is real dam close to a 4" shock extended lenght!! |
