12-10-2005, 06:44 PM | #1 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
| Update on my Walmart special.
Here's my nylint as it sits, chassis needs to be finished and electronics wired and mounted but you get the idea. The stick pack will be mounted lengthwise below the chassis and the RX and ESC will be mounted on the top of that. Tx- Traxxas TQ3 RX- Traxxas TQ3 (broken antennna needs re soldered) ESC- Kyosho Perfex Steering servo- Futuba S3003 Winch servo- Traxxas 2055 modded for full rotation Battery Pack- Duratrax Shark 1500. The chassis is a piece of 5/16" all thread with a piece of brass or copper tubing spacing the axles (I found the tubing laying around my shop, came from a fire poker set don't know material), the shock/body mounts will be 2mm aluminum. Picture of the whole deal minus body and shock/body mounts. And yes the all thread will be cut down, I just haven't gotten to it yet. |
12-10-2005, 07:48 PM | #2 |
Rock Crawler Join Date: Oct 2005 Location: Clarkston, MI
Since I am planning on a stick, I have a few questions: 1. How are you mounting the batteries? 2. How did you do your steering? 3. What's with the wheel on the transmitter? 4. How did you mount your shocks? 5. Are you going to use 2.2s? |
12-10-2005, 08:15 PM | #3 |
1. The pack is going to be zip tied lenghthwise (tube will sit in the little indent between the cells). 2. Steering isn't done yet buy I plan on just a link off the servo using the stock wheel to wheel linkage. 3. I was bored and I lost the foam to the original wheel, its a VMG tire with narrowed wheel. 4. Shocks will just be on some towers out of aluminum mounted on the all thread. 5. No 2.2's here, this is for a scale build. |
12-11-2005, 07:24 AM | #4 |
Nice battery mounting. I can't wait to see what this will look like.
12-14-2005, 05:01 AM | #5 |
Pebble Pounder Join Date: Jul 2005 Location: florida
| dubble post!!!! dang it! Last edited by RIVERdude69; 12-14-2005 at 05:04 AM. |
12-14-2005, 05:03 AM | #6 |
Any progress? Im very interrested in this! Is a great idea. More pics would be nice!
12-14-2005, 04:34 PM | #7 |
No, school work and my new project have been taking up my time. I'll get on shock mounts eventually. I don't get the body till Christmas and I need to solder up some motor leads. I'm going to mount the electronics tonight though.
12-23-2005, 12:33 PM | #8 |
Rock Crawler Join Date: May 2005 Location: In front of my comp
did u thread the thread into the holes where the stock links went? or run it through and use nuts on both sides?
12-23-2005, 12:49 PM | #9 |
Newbie Join Date: Nov 2005 Location: chapel hil
any progress?
