12-24-2005, 06:56 PM | #1 |
Pebble Pounder Join Date: Dec 2005 Location: Fort Worth! Need a Address??
| Rear slipping fix
Well i found another fix for the slipping belts. I first put a o ring to see how it worked and it did great. But then i was reading how people are having problems with them busting. So i put the front "smaller" belt on the rear and cleaned it. It works just as good as the o-ring but may last a lot longer . I will try and find a fix for the front or just buy another front belt. The o-ring that was on the rear is now in the front and seems to do just as good as the stock only its the same size not smaller.
