01-03-2006, 07:28 PM | #1 |
Pebble Pounder Join Date: Nov 2005 Location: South Range
| Patching tire holes after grooving.
What did you guys use to patch holes in your tires after you are done grooving them? I meant to save some left over rubber but forgot. I was thinking of using liquid electrical tape. Christian
01-03-2006, 07:30 PM | #2 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Holes after grooving? Cut too deep, eh? Innertube for a bicycle works to patch...or maybe an innertube patch kit. |
01-03-2006, 08:45 PM | #3 |
Newbie Join Date: Nov 2005 Location: Haysville
I used the waterbed patch kit...I had it anyway, and it works good.
01-04-2006, 10:16 AM | #4 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
Rubberized CA glue works great for me.
01-04-2006, 10:30 AM | #5 |
Pebble Pounder Join Date: Nov 2005 Location: Calaveras County
100% pure silicon architectural grade 50 year caulk (in your choice of colors) from your local hardware store.
02-28-2006, 11:50 PM | #6 |
Rock Stacker Join Date: Jan 2006 Location: hampstead
I just fired up my soldering iron and melted bits of tire in the hole but you could try http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=1400 tire glue: Hobby Etcetera BSI11700 Tire glue .5 oz 20-45 seconds $4.99 Rubber enhanced cyanoacrylate glue. Great for rubber tires, or other joints where a little flex is required. Dries in about 20 to 45 seconds. Made in the USA. When calling or writing, ask for BSI11700 |
03-01-2006, 12:56 AM | #7 |
Rock Crawler Join Date: Feb 2006 Location: Warner Robins
I'd go with this: http://www.hobbyetc.com/cgi-bin/item...#ilikepictures The stuff is the shiz. I only use it. |
03-01-2006, 01:07 AM | #8 |
hello thats what i just posted
03-01-2006, 02:04 AM | #9 |
Pebble Pounder Join Date: Dec 2005 Location: Orem
i left the holes!! it made my tires alot softer and it deflates alot better giving the crawler better grip on the rocks! |
03-01-2006, 05:10 AM | #10 |
Newbie Join Date: Feb 2006 Location: Bumble Screw
I used regular old black rtv silicone. The kind you can get at any auto parts store...probably hardward stores too. nothing special...no special grade. Since I had a few sets of tires around, I did some experimenting. I made a hole no matter how hard I tried not to...so some tires I patched the whole completely over...others I patched most of the hole, and left a small pin hole for that air could escape and make the tires alittle softer. As stated above... If you leave a gaping hole...i think they are too soft. But you can limit the hole size a bit to control the outgoing air. Just a thought...and a combination of the above ideas. I romped on mine pretty good and I havent had the RTV give out yet. In fact...I ripped a hole in a non-rtv area where it was thin from cutting...but the RTV areas stayed perfect. Justin |
03-02-2006, 12:38 AM | #11 | |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
03-02-2006, 06:39 PM | #12 | |
Newbie Join Date: Aug 2005 Location: weirton
