Thread: Looong Rear Driveshaft?
Old 10-13-2004, 01:52 PM   #1
Default Looong Rear Driveshaft?
Need a 7" long rear drive shaft for my crawler project due to this emaxx torpedo chassis I'm modifying - already has the long CVD but it's not long enough - am I going to have to make one?
Any ideas?
Thanks
eb76adam is offline   Reply With Quote
Old 10-13-2004, 01:59 PM   #2
Default Re: Looong Rear Driveshaft?
I saw someone make a driveshaft out of a square bar and a square tube that had Xfactor CVDs on the ends. and also a tmaxx driveshaft that was longer by gluing a inner spline on a long shaft and cutting another outer shaft with the joint cut off , then sliding an out put shaft on it. kinda like a coupler on pvc pipe.
Search around, its out there. good luck
Rene is offline   Reply With Quote
Old 10-13-2004, 02:59 PM   #3
TEAM MODERATOR
Reflection's Avatar
I made my shafts with 1/4" wobblies,1/4" allen wrenches,1/4 sockets and a small piece of 1/2" tube. Came out pretty good,a guy could easily make any length he needed.
Reflection is offline   Reply With Quote
Old 10-13-2004, 04:18 PM   #4
What are wobblies?
Got any pics of the shafts?
Old 10-13-2004, 05:36 PM   #5
TEAM MODERATOR
Reflection's Avatar
Sorry,no pics :( just built them 3 days ago. I'm technologically declined,no digicam. I'll take some with my rusty,I mean trusty ol 35mm though and post up when there developed.
A wobblie is ,well a wobblie.
Seriously though,its a device used in an application in conjuction with 1/4",3/8",1/2" and 3/4" drive ratchets and sockets to reach around corners where theres not a straightline shot.
Old 10-13-2004, 06:12 PM   #6
PapaGriz Yo
Grizzly4x4's Avatar
Wobbly, right?
Grizzly4x4 is offline   Reply With Quote
Old 10-13-2004, 07:05 PM   #7
Ace
I glued several e-max outdrives together to stretch the driveshaft on my shaftie. Worked pretty good, but I'd be concerned about strength in a stock maxx rearend... (mine had 20:1 axles and therefore much less torque)
Ace is offline   Reply With Quote
Old 10-14-2004, 08:48 AM   #8
of course there is always a small twig and duct tape.
DirkDigler is offline   Reply With Quote
Old 10-14-2004, 10:23 AM   #9
Ace
You talking about yer kinky sex days again?
Old 10-14-2004, 10:42 AM   #10
rbgerrish's Avatar
I would suggest using Maxx driveshafts. You can combine a few male and female ends together, glue some of them, to make one long slider. Then slip a brass tube cut to length over the whole thing. This adds massive strength and armor, making the shaft quite beefy. I havent broken mine yet...
Sorry it's not the best picture, but the driveshaft on Graz is like 8".
RYan
rbgerrish is offline   Reply With Quote
Old 10-14-2004, 02:54 PM   #11
RYan
Cool man - got any more pics of this rig?
Old 10-16-2004, 07:30 AM   #12
that is sick
spicollie is offline   Reply With Quote
