Thread: hr dig?
Old 01-22-2010, 11:40 PM   #1
Default hr dig?
i have a HR dig attached to a axial trans, issue i think im having is it seems stiff to go into different positions. I can spin big spur gear by hand easy, but it seems like it either is hard to go in to one of three positions or takes a while (spinning the spur gear) to engage to next one. i took dig apart all moves freely and such. any ideas? I hate to hook it up and burn up servos
pontiacfreak is offline   Reply With Quote
Old 01-23-2010, 12:06 AM   #2
How clean is it, and did you put any lube on it when you put it back together? You might need to just a little bit of filing on it for it to be smooth.
Here are some tips from my HR...
Hot Racing Disconnect Review
Hope this helps.
Greatscott is offline   Reply With Quote
Old 01-23-2010, 12:13 AM   #3
it wasnt super clean but wasnt bad, i will take a look at that in morning when im more aware of what im reading. also what would u lube? and with wat kind of lube? its brand new for most part dont think its been hooked up to a servo yet
Old 01-23-2010, 08:56 AM   #4
what kind of lube or grease and where would u put it? new to having a dig
Old 01-23-2010, 01:16 PM   #5
This is what I use:
http://www3.towerhobbies.com/cgi-bin...?&I=LXGS04&P=7
But just about anything will do, I put in on the linkage where it passes though the back of the dig, where the linkage engages the dig, and a little bit on the dig itself.
