Thread: 3mm rod ends...
Old 01-30-2010, 06:31 PM   #1
Default 3mm rod ends...
I searched and came up empty handed. So can I get some recommendations on good 3mm rod ends?
Need a high degree of misalignment.
I also need bent and straight ends.
I bought RC4wd's ends but they are super brittle and today on my first run with my new comp rig. I broke 4 rod ends. So I need something better...
Thanks.
chris w is offline   Reply With Quote
Old 01-30-2010, 06:45 PM   #2
Bart bender's Avatar
Go with 8/32(4mm) Jato ends. You won't regret the size increase. Otherwise Axial has bent rod ends.
Bart bender is offline   Reply With Quote
Old 01-30-2010, 06:54 PM   #3
Jato are 3mm rod ends, Revo are 4mm (pn 5347). I have the Jato on my rig now and Ive never broke one yet.
BADASSPONY is offline   Reply With Quote
Old 01-30-2010, 07:09 PM   #4
LXKMD6 Tower pt#
These are Jato rod ends and they are 4mm-8/32
OK are you asking for thread 3mm or ball hole 3mm? Most ball ends are 3mm ball hole.
Old 01-30-2010, 07:44 PM   #5
Originally Posted by Bart bender View Post
LXKMD6 Tower pt#
both I just built a new rig with delrin links and want to keep using them so I want to keep it 3mm
Old 01-30-2010, 08:13 PM   #6
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
You can use the same links, just redrill and tap them.
Otherwise you are just going to have to go with standard E-max rod ends. They aren't going to have anymore misalignment than anything else though. As for bent ends, you will either have to use the Axial ends or Losi ends for the LCC.
I highly suggest ditching the 3mm.
Harley is offline   Reply With Quote
Old 01-30-2010, 08:24 PM   #7
Siggy's Avatar
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJ81
These are 3mm/3mm. BUT If you can re-thread your delrin links to accept 4mm-8/32 or get 3/8 threaded rods and aluminum or stainless steel tube sleeves, Bart's suggestion is a stronger way to go.
Siggy is offline   Reply With Quote
Old 01-30-2010, 08:32 PM   #8
how strong are the Losi bent links? i hate the Axial because they strip to easy. And I have run jato ends on my last rig and they dont have as much misalignment as Id like. Plus they arnt bent.
Old 01-31-2010, 08:45 AM   #9
These are all I found. Stormer Hobbies(LOSA6011) has em 4-pak $6.95. 17deg offset
Any good hardware store would have a 4mm tap. I use 8/32 just cause, well it's America Delrin taps out like butter.
Old 01-31-2010, 09:44 AM   #10
I have not used them, mainly the Jato's and Dubro's, but RC4WD has plastic and alum ones
Plastic
http://www.rc4wdstore.com/2/index.ph...72fd815940900b
Alum
http://www.rc4wdstore.com/2/index.php?cPath=28
sweli is offline   Reply With Quote
Old 01-31-2010, 09:55 AM   #11
Traxxas 5469's are the strongest 3mm end's I've found. I've never broke any. I broke several of the ones Siggy linked. The stock axial plastic ones are stronger than those.
http://www3.towerhobbies.com/cgi-bin...?&I=LXHVY5&P=7
Use the stock axial steel balls, they are stronger than the traxxas balls.
Manning is offline   Reply With Quote
Old 01-31-2010, 12:06 PM   #12
Not all stock Axial balls are steel, the ARTR (maybe others also) has plastic balls. I've never had an issue with traxxas balls and Axial ones cost to much if you have to buy them.
indiana mudcat is offline   Reply With Quote
Old 01-31-2010, 01:21 PM   #13
Your right, I keep forgetting 90% of axials are RTRs. The kits have the steel balls stock.
Old 02-01-2010, 10:28 PM   #14
I agree that these are the strongest plastic rod ends you are going to find.
The link is to ball ends that fit the above rod ends that could give you the high misalignment you are looking for.
http://www3.towerhobbies.com/cgi-bin...?&I=LXHGC9&P=Z
corkysk8 is offline   Reply With Quote
Old 02-02-2010, 01:24 PM   #15
chris gimme a shout i can help you out.
ROLANDROCKSHOP is offline   Reply With Quote
Old 02-04-2010, 03:58 AM   #16
2X on these
Rig Rocker is offline   Reply With Quote
Old 02-04-2010, 09:23 AM   #17
I use the Dubro 3mm links and have never had a failure. They are longer than most so you will have to adjust for that.
Gozer is offline   Reply With Quote
