01-10-2006, 04:54 PM | #1 |
Newbie Join Date: Dec 2005 Location: Euless
| T case stuck?
I just put my crawler back together after doin a few things, now the t case is stuck, the back is stuck in high and the front is stuck in low. any idea's it hasent been charged in a while but it runs fine, could low battery be the cause or did i break something.
01-10-2006, 05:16 PM | #2 |
Rock Stacker Join Date: Dec 2005 Location: Loganville
if you've pulled the axle covers off, dollars to donuts you've misaligned the gear on the front shift mechanism. open it back up, make sure the axle for that vertical shift drive gear is seated properly, and try again.
01-10-2006, 05:37 PM | #3 | |
01-10-2006, 05:47 PM | #4 |
hmm. pull the front axle cover anyways and make sure nothing's broken or misaligned. does it make a constant grinding noise if you try to shift, and then stop when you shift back?
01-10-2006, 05:56 PM | #5 | |
yes, yes it does. | |
01-10-2006, 06:46 PM | #6 |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
aww shucks just lock it in low or just glue the shifter on the controller in low, that way it cant move and nothing can try to shift..... but yah, it sounds like something is messed up in the axle. just pull the cover and have a look, theres really no way to mess it up....nothing will fly out at you when you pull the cover. all the gears and in 2 gear cases... most likely the black arm that does the shifting isn't moving like it should be. |
01-10-2006, 07:19 PM | #7 | |
Newbie Join Date: Dec 2005 Location: Loomis
01-10-2006, 07:44 PM | #8 |
yah but if a black button isn't pushed in, the crawler will surge.... roll the cralwer over so that the tires can spin freely, turn it on and pull the trigger....see if it goes, stops, goes, stops..... thats what mine did when i was trying to figure out how to lock it in low..... |
01-10-2006, 07:51 PM | #9 | |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
01-10-2006, 08:12 PM | #10 |
to lock mine, i took out all the shifter stuff, hotglued the slider piece in the low position, clipped the wires to the shifter motor and the 2 buttons, then pulled the wires up into the chassis and clipped them off short. connect the black and white wires together that went to the "low" button....simple as that... the back was even easier, just had to take out the shifter junk and hotglue it. |
01-11-2006, 11:09 AM | #11 |
If you flip your rig over to see whats wrong, it will always surge in the case beacause one axle is stuck in high range. When they are in high range and the tranny sences no load, the tires stop to prevent breakage. So turning it ove to watch the axles spin in different ranges doesnt work and tells you nothing. |
01-11-2006, 04:39 PM | #12 |
thanks guys, i figured it out while i had it taken apart and letting some parts dry, i was doin a TT and decided to take the axle apart and it was the little black actuator thing.
