Thread: help with a honcho
Old 02-11-2011, 09:58 PM   #1
Unhappy help with a honcho
I have a honcho with sidewinder esc and a novac 55t motor and futuba metal steering servo, today while crawling whenever I would steer my speed would become eratic or stop then return when I went to neutral with the steering, thought it was low battery so changed battery and no change.
any help??????
forsaken73 is offline   Reply With Quote
Old 02-11-2011, 10:25 PM   #2
what radio gear? & get a castle bec.
R/CMaxximus5.0 is offline   Reply With Quote
Old 02-11-2011, 11:18 PM   #3
i had a similar problem i was racing a rc8te with the monster system an a high tech servo my motor would bog ever time i turned, the servo was drawing a crap load of power and making a loud motor noise like reeereee the servo was a high tech hsc-5998tg also check your frame rate if your running a anilog servo with digital tranmitter you will have problems
CPT.HOOK is offline   Reply With Quote
Old 02-12-2011, 04:18 PM   #4
Sounds like you need a BEC......
WIDELOAD is offline   Reply With Quote
Old 02-12-2011, 08:54 PM   #5
Thumbs up
got it figured out, I blew up a servo. I installed a new hitec today and it worked fine
Old 02-12-2011, 09:59 PM   #6
Suck it up!
Duuuuuuuude's Avatar
You still need a bec. Its pretty much mandatory when you have a crawler.
Duuuuuuuude is offline   Reply With Quote
Tags
esc, honcho sx-10 scaler, sidewinder
