Thread: Setting up Felstenfest lockers.
Old 02-10-2010, 08:14 PM   #1
Default Setting up Felstenfest lockers.
When I set up my felstenfest locker I'm having trouble getting the axle shafts to run perfectly true. I can get them super close but not perfect. Am I being too picky or do I need to keep playing with it. Help!!!!:?
mudman1 is offline   Reply With Quote
Old 02-10-2010, 08:20 PM   #2
Well, Christian recommends drilling an access hole in the housing and then closing it with a set screw...personally, I just keep adjusting them. If you loosely bolt them down, then put the spool/axle shafts into half of the housing, then you can rotate the shafts and tighten down the set screws as necessary.
JeremyH is offline   Reply With Quote
Old 02-10-2010, 08:45 PM   #3
Tried it both ways with the same results. Like I said, they are close but there is still some runout that i can't seem to get rid of.
Old 02-11-2010, 03:55 AM   #4
I use them in both of my comp rigs and heres what I do. I screw the set screws in until I see them flush with inside of hole. Then install axle shafts and tighten them the exact amount in small 1/8 turn increments. This should get you set straight. I put two set screws in my axle housings for later axle removal without teardown.
Rig Rocker is offline   Reply With Quote
Old 02-11-2010, 05:22 AM   #5
That is strange. I cant understand how, if you bolt the axle cases together, you are still getting a wobbling axle shaft. The bearings should be holding it in place. Are your cases, by chance, worn out at the bearing races?
Old 02-11-2010, 06:38 PM   #6
It's wobbling because he doesn't have the set screws evenly set
Old 02-11-2010, 07:37 PM   #7
Thanks Captain Obvious.
I meant, I don't understand how, if he bolts the case halves together, he can possibly tighten the set screws down so that they cause the shafts to wobble. I have been running these spools for quite some time now and have no troubles getting them aligned properly.
Old 02-12-2010, 02:19 AM   #8
i adjust mine carefully before i mount the spools to the ring gear
EGRESSor is offline   Reply With Quote
Old 02-12-2010, 03:25 AM   #9
Captain Obvious! LOL, Thats funny Jeremy Didn't realize that was you that I was quoting. Thought is was someone else who needed the obvious stated
Never have a problem with mine either
