Thread: Scorpion Vs. Jeep
Old 12-19-2005, 01:11 PM   #1
Default Scorpion Vs. Jeep
We know the chassis is the same for both...
But it would be nice if we could get some numbers from guys with both or either
Body weight
Body width
Overall height (mounted on chassis)
Approach and Departure angle
Can the cage be removed from the scorp like the jeep's cagework and windshield can?
Mutt is offline   Reply With Quote
Old 12-27-2005, 10:01 AM   #2
Powered by Awesome
TwistedXT's Avatar
BUMP...
I was wondering the same thing... has anyone wieghed both bodies by themselves... was wondering which one had less floppin around up there....
TwistedXT is offline   Reply With Quote
Old 12-27-2005, 02:17 PM   #3
None body movement here
ColquittCustom405 is offline   Reply With Quote
Old 12-27-2005, 02:21 PM   #4
Diggin' the new SCX10 II!
badger's Avatar
I have both but I am too lazy to get all that info. :?
Maybe I will do it today.
badger is offline   Reply With Quote
Old 12-28-2005, 12:33 PM   #5
Well now it's tommorow, so how bout them numbers?
Old 12-28-2005, 04:00 PM   #6
Numbers for the jeep:
Body weight = ~3 pounds, not sure on the accuracy of the scale
Body width = 11 inches
Overall height (mounted on chassis) = 14 inches
Approach angle = >90 without stinger, little less with it
departure angle = ~80
You're lucky I'm bored!
bobbo27 is offline   Reply With Quote
Old 12-28-2005, 06:33 PM   #7
Default scorpion
The scorpion body is also three pounds, not sure abouth the approach or departure angles, but it seems a lot les top heavy with the scorpion
-will
dodgem37 is offline   Reply With Quote
Old 01-13-2006, 01:42 PM   #8
Powered by Awesome
TwistedXT's Avatar
im picking up a scorpion and a friend has a jeep... my wife runs a UPS store so i will put both bodies by themselves on the scales and get an exact reading down to the oz. it'll be about 2 week till i can do it though... so... sit tight.
Body wieght is the only thing i care about but i will try to get the other reading to while im at it. i suppose.....
Old 01-13-2006, 10:25 PM   #9
Why the hell does body weight matter when you have a gazillion pound battery?
Otto Man is offline   Reply With Quote
Old 01-14-2006, 02:48 AM   #10
Believe it or not it does a little. But every little bit helps. I'm not saying this b/c I'm a big Jeep fan, but for the simple fact that one can do more Body work and Fab'ing with a Jeep body. A cut up Jeep just looks COOL. And all the cool kids are doing it.
Old 01-14-2006, 06:41 AM   #11
Play around with your crawler a bit, then pull the body off and do it again, i bet it sidehills better
Old 01-14-2006, 03:22 PM   #12
I have one of each as of about 3 hours ago. The weight difference is as follows:
NONE. I weighed each of the bodies and mine weigh exactly 3 lbs a piece. The dimentions are totally different. The body on the Scorpion tucks the tires much better. Approach and departure angles are better also.
ford381stroker is offline   Reply With Quote
Old 01-14-2006, 05:03 PM   #13
i have both and the scorp is i bit more top heavy to me anyway i seem to
roll it a bit more then the jeep and yes the jeep and scorp chassis the same i have three all together chassis anyway
Snow is offline   Reply With Quote
