02-23-2010, 07:36 PM | #1 |
Newbie Join Date: Jan 2010 Location: On a baot
| brushed vs brushless
i was wondering, i have a Novak Rooster w/ 45t in a ax-10, and my crawler torqe rolls bad, i was wondering if i went brushless would the smother motor reduce the tourqe roll at all, if you need any of the specs on the crawler to better answer the question, just let me know Thanks Daniel |
02-23-2010, 07:38 PM | #2 |
Rock Crawler Join Date: Sep 2008 Location: Salem,Oregon
mirror the tranny helps alot and is free 4link it helps some more put a stiffer shock in the rear on the side that is squating hope that helps |
02-23-2010, 07:51 PM | #3 |
Mirror the tranny?, im kinda new to the crawling what exactly does this mean?, and thanks for the fast reply
02-23-2010, 07:55 PM | #4 |
A brushless motor will not reduce torque twist....but it will reduce motor drag (not a good thing in a crawler)...
02-23-2010, 08:11 PM | #5 |
Rock Crawler Join Date: Nov 2009 Location: Wasilla Alaska
| mirror
Means turn the motor and tranny around in the car. Doing that eliminates most of the torque twist. If the car is picking up the left front tire put a stiffer spring or heavier shock oil in the right rear spring. That will help with torque twist as well.
02-23-2010, 08:24 PM | #6 |
RCC Addict Join Date: Jun 2008 Location: Fresno
lots on info on this board about cures for torque twist. and its all just a search away mirroring the tranny is actually not all it's cracked up to be. things like adding wheel weight, switching up link geometry by fine tuning a 4 link system, different springs and even varying oil weights is a much better option imho i prefer not to get anyone on rcc thinking im a pompous know-it-all but when i read advice "mirror the tranny" first thought that comes up in my mind is "newb." not because it's particularly bad advice but, in the end you will go back to an "unmirrored" tranny and back to the original question no brushless will not help fight torque twist. a rotating mass is a rotating mass. stick w/ brushed. its cheaper, you have better drag, its smoother, and most times a lot lighter and smaller (motor and esc weight and size combined) Last edited by NeXt559; 02-23-2010 at 08:29 PM. |
02-24-2010, 02:09 PM | #7 |
Newbie Join Date: Feb 2010 Location: nc
um, less weight with brushed? not meaning to flame but with an outrunner and a micro sidewinder it weighs about the same as a brushed motor...then add in the weight of the esc.......
02-24-2010, 03:33 PM | #8 |
Rock Crawler Join Date: Oct 2009 Location: 6512 Elevation
I think if you read this thread it will help you out Anti Squat and Suspension Tech |
02-25-2010, 09:00 AM | #9 | |
lets try to compare apples to apples the micro sidewinder is designed for 1/18 application, plus the popular fx-r is smaller and lighter then the cc swm as for the outrunner, is there any sensored ones out there that can compare to the price, low speed precision control and "smoothness" a brushed motor ? until then i think i'll stick w/ brushed. and also stated "in most cases," i did not say all Last edited by NeXt559; 02-25-2010 at 10:42 AM. | |
