03-26-2010, 12:31 PM | #1 |
RCC Addict Join Date: Aug 2005 Location: Akron
| Source for pillow blocks (for 5mm or 6mm shafts)
Anyone have any sources for pillow blocks? This is basically EXACTLY what I want but $12 each seems steep? I'd prefer 5mm but 6mm will work if need be. http://www.robotshop.ca/lynxmotion-p...ock-pb-02.html |
03-26-2010, 12:34 PM | #2 |
Have you checked McMaster?
03-26-2010, 12:39 PM | #3 |
03-26-2010, 01:13 PM | #4 |
03-26-2010, 01:26 PM | #5 |
Quarry Creeper Join Date: Jul 2005 Location: pleasant ridge
It's not as pretty, but you could make one out of a axle carrier.
03-26-2010, 02:30 PM | #6 |
In all actuality,12 bucks for a part like that REALLY ain't that bad. Unless you sources them out to a chinese sweat shop. I could make something like that pretty easy at the shop myself,for $12 though....I'd just buy the dumb thing. |
03-27-2010, 04:05 PM | #7 |
yeah, I'm gonna say $12 is about as good as you are going to get bud
03-27-2010, 05:23 PM | #8 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
Out of curiosity, what are you going to be doing with it?
03-27-2010, 05:46 PM | #9 |
I'm going to guess a carrier bearing fro his huge ranger..
03-27-2010, 10:43 PM | #10 |
Quarry Creeper Join Date: Mar 2004 Location: Massachusetts
I used the nylon/plastic sleeve bearing in a 2.2 crawler build... worked fine all season and inexpensive. 5mm #6687K31 6mm #6687K32 |
03-27-2010, 10:51 PM | #11 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
When I built the drive lines on the Man-kat 8x8 I used a tlt knuckle with the arm shaved off and mounted with the 2 pivot holes, works great for 3 years and only cost about 35 cents + bearings isn't as small as those but its solid.
03-29-2010, 04:40 PM | #12 |
Quarry Creeper Join Date: Nov 2006 Location: Manchester
03-29-2010, 05:49 PM | #13 |
| How did you know that!? Haha! Kona joe, i actually seen those and got my attention but do you think they will last at 10,000rpm? I didnt think they would last long. Might just have to cough up $30. I was just thinking there might be something stock out there cheaper. |
03-29-2010, 06:41 PM | #14 | |
03-29-2010, 07:14 PM | #15 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
If you are limited as far as space goes, you could do what I did. I made a carrier out of a piece of 3mm aluminum (bent at the correct angle), drilled an 5/16" hole in it and pressed in a 5x8 flanged bearing held with 609 Loctite. Not the prettiest but works great and cheap. |
03-30-2010, 06:20 AM | #16 | |
03-30-2010, 06:42 AM | #17 |
Hi-Lift bellcranks work well, too.
03-30-2010, 09:30 PM | #18 |
