01-23-2006, 01:38 PM | #1 |
Newbie Join Date: Jan 2006 Location: Bethlehem
| Questions?
Does adding bb's and cutting the tires really make a difference? Should I do both or is doing one or the other good enough? |
01-23-2006, 02:20 PM | #2 |
Newbie Join Date: Jan 2006 Location: A City
Cutting the tires is a most. Most people cut them for better traction cause you can tell with it it sone they suck. Adding BBs to the front helps, but depending on if your climbing kind of steep rocks then you should add some if you are having a prob with it trying to flip backwards. Do a search and type in BBs and you will find all you need on this. Hope this helps. Another thing bbs are used for weight. to the front or back of your rig.
01-24-2006, 05:06 AM | #3 |
Thanks for the info E-Maxx. I know that cutting and siping tires helps with real rock crawling. I have a '90 Wrangler with 8" of lift and 37" GY MT/R's. With a lot of other goodies as well. But I'm new to this whole RC thing and wanted some info on that. Guess I'll be cutting up some tires tonight.
