01-23-2006, 05:47 PM | #1 |
Pebble Pounder Join Date: Sep 2005 Location: Auburn
| Wow..Steeering broken completly....
How do I get into the sterering box?? I can't really figure it out. I broke the black piece that runs from that black box over to the grey piece....anyway, I need to fix this somehow. Anyone got any tips on how to?? Main problewm right now is that I I can't even get into the box to see how i all works.
01-24-2006, 07:40 AM | #2 |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
you need to take apart the axle to get to the steering. just take out all the screws on the bottom and pull.
01-24-2006, 10:26 AM | #3 |
Yea, i finally got it. I got tired of sitting around waiting on someone with an answer so I said screw it.....i',m on my way to HD right now to get the last pieces to finsih up the steering. It should be pretty damn stout now...
01-24-2006, 11:00 AM | #4 |
Newbie Join Date: Dec 2005 Location: Loomis
updates on your fix. I'm tired of mine being broke while I wait for a new one. thanks |
01-24-2006, 11:47 AM | #5 |
I'll get you some pics, i'm about to finish it up right now...
01-24-2006, 11:51 AM | #6 |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
how do you get the drag link through the axle case? it hangs up on mine. i want to pull the steering setup out to see how its wired and to clean the belt because it was slipping bad...
01-24-2006, 07:24 PM | #7 |
Slammed, Remove the rivit pin thing from the pitman arm and drag-link (end nippers work best) turn the wheel on your controller until the pitman arm lines up with the notch in the axle. pull it out. Done Put a cap srew and nut back on to attatch the pitman arm to the drag-link, its eazier than trying to push the rivit back in. Sorry for stealing you thread Zach. |
