01-27-2006, 10:12 AM | #1 |
Newbie Join Date: Jan 2006 Location: THE ‘BURG
| Esc Choice Question
Just Wondering What Type Of Speed Control Some Of You Guys Are Running In Your 1:18's
01-27-2006, 11:23 AM | #2 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
i am runing a Novak Rooster in mine . just because i had it laying around . but would like to find somethink alittle smaller . it is tight in there. but it will work . i did the tummy tuck . and keep the batter pack in the center of the truck with the Rooster in the front and the receiver in the back . had to leave the cover off . but body will fit with out raising it up . i did keep the batter door on the bottom . just take the screw out of it an drop the batter down like stock . that way i don't have to take the body off to charge.
01-28-2006, 11:08 AM | #3 |
Thanks I Have Always Had Nitro So I Didnt Know About The Two Motor Thing,didnt Know If You Needed A Esc That Was Specialy For Two Motors I Just Bought A Losi Mini T And It Looks Like The Speed Control Is Designed For Two Motor Two Red Leads And Two Black So That Kinda Threw Me Off
01-28-2006, 11:56 AM | #4 |
Pebble Pounder Join Date: Dec 2005 Location: Metro NYC
a mini t uses one motor. If it has 4 leads.....two are for the battery and the other two are for the motor. Now if you have a mini lst it will have 6 leads....4 for 2 motors and 2 for the battery. You can use two motors on a esc that was designed for a single motor. Provided the esc has a higher rating than the 2 motors. You need to wire the motors in parallel.
01-28-2006, 01:05 PM | #5 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
If you're talking about a 1:18 nylint, you're fine running a regular single motor ESC.
01-30-2006, 10:49 AM | #6 |
Quarry Creeper Join Date: Jan 2006 Location: Siler City, NC
