01-28-2006, 02:47 AM | #1 |
Pebble Pounder Join Date: Nov 2005 Location: Honolulu
| FUBARED Steering arm
I broke the piece that connect the steering motor to the pitman arm. Its that piece that has a pin in itand swivels when you turn. Tried to Krazy Glue it, but that just broke off again. When I e-mail Nylint, what piece should I tell? I don't want to replace the steering mech, just this arm. I think I must replace the part that takes the output of the steering box. If that makes any sense... And how do you guys remove these pins? Mine are stuck beyond belief... |
01-28-2006, 10:35 AM | #2 |
Newbie Join Date: Jan 2006 Location: Knoxville
I use a pair of dikes to squeeze under the pin and the arm. This worked well for me and barely scraped the plastic.
01-28-2006, 11:08 AM | #3 |
Newbie Join Date: Dec 2005 Location: Loomis
End nipper dykes work the best, because they will pull it straight out
01-30-2006, 07:08 PM | #4 |
Neat. Got any pictures of these cool tools? And what part should I ask of Nylint? |
01-30-2006, 07:13 PM | #5 |
Pebble Pounder Join Date: Dec 2005 Location: Orem
| what works best for me.....
is take a lighter,, heat up the plastic alil bit, then pull out the pin with dikes! i found that to be the best way to fix that problem! (be careful you dont melt the plastic) it only takes a lil bit of heat to get it out |
01-30-2006, 07:31 PM | #6 |
Pebble Pounder Join Date: Sep 2005 Location: Rapid City
I broke the same piece (trying to upgrade the knuckle tower) but I'm just going to replace it with a screw in eye hook.
