04-29-2010, 09:41 PM | #1 |
Quarry Creeper Join Date: Mar 2010 Location: canada
| tire rub
so here is the scoop. ive got a ax-10 platform. warthog chassis, 3racing shocks ( inner springs) aluminum links and rc4wd rocklin crawler tires. my problem is that my tires rub at full turn on the shock body. can i solve this by pushing my shock lowers and my links more inboard on the axle, or will this affect my flex to much? please help has anyone else had this problem.
04-29-2010, 10:30 PM | #2 |
RCC Addict Join Date: Oct 2009 Location: Council Bluffs
what i have done to remedy my situation like yours is to set my epa on the radio just before it rubs the shock body. yes you will lose some throw but its an easy fix that require no mods |
05-01-2010, 02:37 PM | #3 | |
Quarry Creeper Join Date: Nov 2009 Location: East Bay
Every one.... seems not to be an issue..let em rub and keep all of your steering...You can stiil in board your shocks and links,but then you can increase your steering and the tires will still rub..only issue I have seen is with threaded shocks the tires can catch the adjusters and preload your shock, but with internal springs that will not be an issue | |
05-02-2010, 03:20 PM | #4 |
tryed to mount everything inboard more, still tire rub, hacked some lugs off the inside of the tires, still rubs. put my stock axial rims and tires back on the front. no more rub. "fixed"
05-03-2010, 01:07 PM | #5 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
05-03-2010, 02:21 PM | #6 |
Newbie Join Date: May 2007 Location: UK
You could offset your shocks inboard, that shouldn't effect your articulation too bad, but changing your link location might well effect articulation. But as said above, let em rub and keep your steering at it's max |
05-03-2010, 02:55 PM | #7 |
Rock Stacker Join Date: Sep 2009 Location: griffith nwi
need more offset on yoru wheels shouldnt buy anything else just get correct wheels
05-06-2010, 11:39 AM | #8 | |
Quarry Creeper Join Date: Oct 2007 Location: Ft. Wright, KY
I would not suggest reducing steering throw. Look into what wheel offset will work with your axles... or just Let'em rub! | |
05-06-2010, 01:49 PM | #9 |
Rock Crawler Join Date: May 2009 Location: Idaho Falls, ID.
these guys will build you a wheel out of delerin with a zero and or no backspace. that will help you!! (www.eritexinc.com)
05-06-2010, 11:57 PM | #10 |
| Still don' know what the issue is......if they ant rubbing then you ain't steering....look at a guys rig who is winning every week end..pretty sure the paint on his springs will be worn off |
05-08-2010, 12:32 AM | #11 |
Quarry Creeper Join Date: Jan 2009 Location: Rocklin
| I agree! you could move the shocks in or more backspacing or just let them rub... its your choice in the end try it all and see how i works for you..
