02-03-2006, 10:20 AM | #1 |
Newbie Join Date: Nov 2005 Location: Hermitage
| Steering help
Hello all. I am putting this question up for a freind. He has a 1:6 Scorpion 3rd Generation. and he has little or no steering. He has preformed the fix that Mutt posted for more sterring umph. and it was still weak. He also pulled the steering motor out of his 1:6 Jeep, still same problem. He checked the voltage at the motor and he was getting 11.6 at the motor. He then hooked the motor to straight 12 volts and the motor ran fine. He also did the O-ring. He also took all the steering parts out of his Jeep and still has got little or no steering. He checked to make sure thier were no cold solder joints. Still has the same problem, so if anyone has any other idea's please let us know, cause as it is he is out of commision. BTW he also bought a new motor from Radio shack and it also did not help.
02-03-2006, 11:11 AM | #2 |
Quarry Creeper Join Date: Jun 2004 Location: Fairmont
Maybe he tightened the steering rod ends too tight to the steering knuckles. Tell him to loosen the screws that attach the steering rod to the steering knuckles a little bit and see if that helps. Cause if they are too tight, they will hinder steering a good bit. Clark |
02-03-2006, 05:30 PM | #3 |
Pebble Pounder Join Date: Sep 2005 Location: Auburn
Mine did something similar, and jsut like the last guy said, all it was, was taht I had tightened the rod ends too tight on the knuckels, and that kills the steering by not allowing the knuckles to move freely....try loosening them up and see if that helps.
02-03-2006, 07:17 PM | #4 |
ok I will have him give it a shot thanks
