05-26-2010, 10:35 PM | #1 |
Quarry Creeper Join Date: Apr 2010 Location: The basement of the science building.
| Someone With a Lathe
I'm looking for someone willing to volunteer time and material for a very simple project. I am helping "KNIFE" get his new DX7 set up for his use. The last items needed to complete this project are two stick extensions. They should be made from one inch solid round aluminum stock, Three inches long with a .5" hole drilled two inches deep on one end. The other end should have a slight taper and a hole threaded for 4mm, the thread size of the sticks on a DX7. In case you missed his thread about a month ago, he is a paralyzed Marine who used to compete in the 1:1 crawler world. He is now getting into RC. I have made a few mods to the radio but I can't find anyone local to do this machine work. I too am in a wheelchair and have to rely on public trans so finding a machine shop has been a real challenge. Please let me know if you can lend a hand! |
05-26-2010, 10:59 PM | #2 |
Rock Stacker Join Date: Jan 2008 Location: Riverside
i can help, is there any way u could sketch up a cross section to show how tapered, etc.? any way of finding out for sure what the thread is?(i have never seen a dx7 in person) i wanna get them exactly how he needs them.
05-27-2010, 12:26 AM | #3 |
Yes...I will try my luck with Draw and try to create something. The thread size is 4mm. I have confirmed that. I will get back to you during the day with some sort of drawing and thanks!
05-27-2010, 12:46 AM | #4 |
Rock Crawler Join Date: Jun 2009 Location: SF
I also have a lathe and would be glad to help if needed.
05-27-2010, 01:27 AM | #5 |
05-27-2010, 01:30 AM | #6 |
Newbie Join Date: May 2010 Location: Geneva, Switzerland
Hi, I am happy to help you sketch this up. I have not added dimensions to this drawing but wanted to capture the concept first. Does this look about right? Thanks, Serge |
05-27-2010, 02:02 AM | #7 | |
The stock is 1" aluminum round rod. The large hole is .5" in dia. and 2" deep. The small hole on the tapered end is 4mm threaded for the DX7 sticks. The depth of the threaded hole should be 1" so it will punch through the stock into the larger hole. The depth of the taper is not critical and is for aesthetics. Of course all edges must be chamferred. This fellow wheres gloves that each have a pencil which sticks out about two inches. He will need to insert this pencils into the .5" holes to operate the DX7s sticks. Keep in mind he is paralyzed from the chest down and has VERY limited use of arms, hands and fingers. If you would fine tune the drawing and insert the dimensions, we could be well on the way to completing this project. You are the man!! | |
05-27-2010, 03:03 AM | #8 |
Here's my drawing. A bit embarrassed I must say I am but since I took the time to draw it, might as well show it.
05-27-2010, 04:04 AM | #9 |
Pebble Pounder Join Date: Mar 2010 Location: Flat Orlando
I'll do it. I have 3 lathes at my disposal at any time. I own the business. Glad to help any guy who defended our country. I happen to have the 1" round in my garage. I could do it this evening when I get home. Has any one been assigned the job? I'll need an address to send it to. Lastly...I have white delrin and black delrin in 1". |
05-27-2010, 04:16 AM | #10 | |
05-27-2010, 05:41 AM | #11 |
Hello, Just to finish what I started, here is the drawing. Let me know if there is anything you would like changed. Else I guess someone can machine it Regards, Serge |
05-27-2010, 06:58 AM | #12 |
Quarry Creeper Join Date: Aug 2008 Location: iderho
This is RCC at its finest right here. Im so happy to see everyone going way out of their way to help someone who defended our country. Props to everyone in this thread. |
05-27-2010, 07:03 AM | #13 |
it isn't who helps, but that there is help. i was also concerned with the thread pitch not just the diameter. post up if you need anything else so we can get this soldier rollin'.
05-27-2010, 09:06 AM | #14 |
Excellent, I'll start now. You want a standard 4mm thread, correct? That is 4 mm x 0.7 pitch. thats is coarse thread. there is a fine one too. 4mm x .75. EVERYTHING I do in metric is coarse thread, normally. I'll make it assuming its all standard. When it comes time to tap the hole, i'll check my messages or the forum to see. Glad to help! |
05-27-2010, 09:29 AM | #15 |
4mm by .7 it is then.
05-27-2010, 09:40 AM | #16 |
Finished "Knife's" part. Ship it Sat morn. This soldier is rollin'.
05-27-2010, 10:08 AM | #17 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
this is awesome. i wish i would of caught this thread earlier. FM, how'd it turn out? any pics?
05-27-2010, 11:12 AM | #18 |
I already have it packaged up, so no, no pictures. Its polished and sweet lookin', perhaps Tailrotorblade can post one up when he gets it. I'm going to try and go to the PO today after work. I hope.
05-27-2010, 12:00 PM | #19 |
I'm speechless! I must say though I am unsure if the stick thread is considered coarse. We'll find out but I'm thinking it is fine. Did you get my PM Ben? |
05-27-2010, 12:01 PM | #20 |
| Unbelievably nice and fast. This made project happen! Don't know how to thank you beyond saying thank you! |
