06-01-2010, 01:05 PM | #1 |
RCC Addict Join Date: Feb 2006 Location: ccxc
| Prevent rollback?
Any way to help with rollback when switching dig position ? Like on an incline if I want to lock or vice versa the rig will roll back a bit incurring a reverse penalty. It is an AX10 and a VP Hurtz dig. I am assuming it is the nature of the beast(a shafty) but wondering if anyone know a better way(other than moa!)
06-01-2010, 01:08 PM | #2 |
When I judge, I look to see if it's a shafty and don't count those little rollbacks as reverses. But no, I don't have any help for that question. |
06-01-2010, 01:26 PM | #3 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Sometimes tough to time right, but I try use a small amout of throttle when using the dig.
06-03-2010, 09:03 AM | #4 |
Pebble Pounder Join Date: May 2006 Location: St. Louis
A high quality motor like a handwound will help too or at least it did with my shafty when I had a DNA dig on it. The higher quality motors seem have better holding power.
06-03-2010, 03:52 PM | #5 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
A stronger/faster servo will help. I remember back when I had my shafty--when going from unlock/lock you get some rollback due to the nature of the DNA dig unit. Granted a faster servo helps but if the mechanical parts are not lined up internally your just going to have to adjust your driving style.
06-03-2010, 04:04 PM | #6 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
Just "the nature of the animal". Any mechanical/geared dig/trans will go to neutral between shifts. I guess ya could try and rig up some kind of a driveline brake with the dig servo as it goes through neutral???? Just another reason to go moa! Last edited by oldhippie; 06-03-2010 at 04:08 PM. |
06-03-2010, 04:20 PM | #7 |
RCC Addict Join Date: Nov 2004 Location: union
06-03-2010, 04:20 PM | #8 | |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
As already mentioned, a faster servo will help a little. This is part of the problem of a normal ring and pinion shafty, such as an Axial. The Losi doesn't exhibit this problem due to the worm gears not allowing unpowered roll. This was the biggest reason why I retired my AX10 comp rig and went to a MOA. Quote:
Now, maybe in a local comp...especially if you have a novice or amateur class, that's not a bad idea, but if somebody is in a points series or running for a certain placement, then you're cheating the rest of the competitors by allowing guys with inferior equipment to have a pass. | |
06-05-2010, 11:03 AM | #9 |
Rock Stacker Join Date: Oct 2009 Location: Boston
I think you should go to your LHS and pick up a MOA setup..... |
