06-05-2010, 04:11 PM | #1 |
Rock Stacker Join Date: Oct 2008 Location: Toronto
| chassis reinforcement
I want to reinforce my chassis a bit more. I was thinking a threaded rod through the two plates and then tighten it with 4 nuts. Any other ideas? |
06-05-2010, 04:43 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
I'd use Delrin or other plastic tube/rod available at LHS. Spare links, cut to fit? Your idea is fine. If you sleeve the all-thread with alum tube or shrink tubing it'll look better (if it matters). All depending, you may not necessarily need the outside nuts. Last edited by JeepinOR; 06-05-2010 at 04:46 PM. |
06-05-2010, 06:07 PM | #3 |
Quarry Creeper Join Date: Apr 2010 Location: Natchez
Thought I would add this . If you have trouble finding aluminum tube you can buy knitting needles at walmart ( or anywhere like it ) . These needles come in various sizes and colors and are hollow . Just cut to length and slide over some all thread and youre done .
06-05-2010, 06:11 PM | #4 |
What chassis?
06-05-2010, 06:19 PM | #5 |
thanks alot guys for the replies. I think I will get a threaded rod and an aluminum tube to make it look nice. I have a Venom Creeper, I removed the battery tray so I will need a link to make it more rigid. I was thinking an aluminum tube with thread in it and I can cut whatever length I want and use two screws on each side. But I don't think I can find that... But the problem is I can't use it in the front where the motor is because the motor is in the way. I'm looking for something like this? I tried it today and failed, couldn't get a good bend. |
06-05-2010, 08:20 PM | #6 |
I read that the brace from the AX10 will work fine, thanks guys!
06-05-2010, 08:59 PM | #7 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
Yeah I use a 101mm Axial lower link and just bend it into an arch to fit over the motor and cut to length,,if you cut out too much of the threads then use a black oxide M3 socket head screw or an M3 tap to make deeper threads in the ends.
