02-14-2006, 05:01 PM | #1 |
Rock Crawler Join Date: Feb 2006 Location: Easthampton
| Pnuematic steering
im in the middle of helping out the guy at my lhs build a txt. we were talking about using either pneumatic or hydralic steering. we may use these http://surpluscenter.com/item.asp?UI...00&catname=air, but we cant think of anything that we can use for a pump and would automatically return the steering to center.do you guys have any ideas on this topic?
02-14-2006, 05:37 PM | #2 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Here is a few threads that may help. It has been done before. http://www.badgerracing.com/~rcracer...light=scorpion http://www.badgerracing.com/~rcracer...light=scorpion http://www.projecttwin.com/Scorpion_...awler_5081.cfm Last edited by Mnster; 02-14-2006 at 05:39 PM. |
02-15-2006, 05:48 PM | #3 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Moved to General Crawlers, it'll get more views here.
02-18-2006, 06:00 PM | #4 |
Newbie Join Date: Nov 2005 Location: australia
| real hydraulic steering
Hi there, I have actually had the great opportunity to drive a full scale monster truck in NZ and when i was being tought to drive it i was told that because it has hydraulic steering the steering will not self center and therefor i would need to make the truck drive straight. It was the best fun of my life. Ashley |
02-19-2006, 10:19 PM | #5 |
Rock Stacker Join Date: Jan 2006 Location: newhampton
what about using this same cyl. with fluid and another just like it on the other end hooked to a servo to pump the fluid back and forth....?do you follow...this should also self centeras long as it dosent leak too bad.you could put the servo where ever you wanted. I may do this also...I am new to rc but love it I have a crap nylint with crap steering. I was just looking into shocks but this would be easier....good luck Last edited by shawnf6; 02-19-2006 at 10:24 PM. Reason: oops |
02-20-2006, 02:33 PM | #6 |
| ya i got what you were saying. me and the guy at the shop tried using 2 shocks connected together with tubing and we couldnt get the air to bleed out all the way so that idea sucked!!!!!!o well gotta keep thinking |
02-20-2006, 03:38 PM | #7 | |
Rock Stacker Join Date: Dec 2004
that can be changed by simply putting in a different steering control valve. the valve in my 1:1 allows self-centering on my full hydro steering setup. | |
01-06-2010, 07:03 PM | #8 |
Rock Stacker Join Date: May 2007 Location: Vivaa Las Vegas!(Ringgold Ga. is home)
| i hadnt even considered this before... hmmmm... did it leak at all? what shocks did you use?
