07-21-2010, 02:33 PM | #1 |
Rock Crawler Join Date: Oct 2009 Location: home town marsing
| hydraulics
Qt. on hydraulics. wanting to run rams on my axles for steering. if I run a ram that has a inside diameter of 10mm x 85mm . If I want the ram on the axle to push more power to. will I have to run a smaller dia. cylinder with a longer stroke,or just the opposite bigger bore with a shorter through. If you can't tell by now I'm not all that familiar with how hydraulics work. Thanks for your reply and info on this one.
07-21-2010, 02:42 PM | #2 |
Larger diameter with a shorter stroke if you are not increasing your pressure.
07-21-2010, 02:44 PM | #3 |
Rock Crawler Join Date: Jul 2009 Location: waterville
found this thread that may help you out.Hydro steer made easy |
07-21-2010, 03:05 PM | #4 |
Pebble Pounder Join Date: Feb 2005 Location: Chandler, AZ
the actuator cylinder needs a small diameter, long stroke cylinder. The steering cylinder should be larger diameter with just enough stroke to meet your needs. ratio of piston areas is approximate mechanical advantage. Too much mechanical advantage and the actuator cylinder will need to be unrealistically long to achieve full steering throw. |
07-21-2010, 04:28 PM | #5 |
thank's guys that is alot of help, tried to find build threads, never could find any.
