08-29-2010, 06:01 PM | #1 |
RCC Addict Join Date: May 2010 Location: The heart of the south
| Steering problem
I have a timber Wolf and just moved the steering servo up to the frame. I am using a Hitec HS7954 server and a arm with bent metal rod ends. Steering to the left is not bad but to the right, the nose of the truck lifts till the shocks are fully extended. I think a High Steer Knuckle would help but I don't seem to be able to find them for the T-Rex 60s. I may see if I can modify a set of Axial's High Steer Knuckles, but not sure how that will work. Going to aluminum knuckles would probably help as the knuckles seem to flex a lot on top of the bolt I am using to secure it. Any other ideas of experience with this? Forgot the Pics. Last edited by neillarson; 08-29-2010 at 07:38 PM. Reason: pics |
08-29-2010, 07:29 PM | #2 |
RCC Addict Join Date: Apr 2009 Location: United States of the Offended
Some pics would be a big help. |
08-29-2010, 07:30 PM | #3 |
RCC Addict Join Date: Jan 2004 Location: Gunbarrel
You need to install a Panhard bar to locate the axle. Otherwise your continue to have this issue. The knuckles will help with strength but do nothing in solving the problem. I'll see if I can find a picture of one that I have installed on mine.
08-30-2010, 07:26 AM | #4 |
| Great, appreciate it.
